Wittman type tubular steel gear
Discussion in 'Hangar Flying' started by orion, Mar 25, 2009.
  1. Mar 25, 2009 #1
    orion
    orion
    orion
    Mar 3, 2003
    5,800
    135
    Western Washington
    Recently we touched upon tubular steel landing gear as associated with the Wittman airplanes and as now used by RV and others. Someone here posted a link to an Oregon fabricator of that gear but I can't seem to find it. Anyone?
    Thanks.
  2. Mar 25, 2009 #2
    DaveK
    DaveK
    DaveK
    Apr 22, 2007
    343
    17
    Northern California
    Re: Whitman type tubular steel gear
    I think Harmon Lange's business is who you are looking for. Langair Machining, Inc.
    Dave
  3. Mar 26, 2009 #3
    orion
    orion
    orion
    Mar 3, 2003
    5,800
    135
    Western Washington
    That's the one - thanks.
  4. Apr 14, 2009 #4
    Turd Ferguson
    Turd Ferguson
    Turd Ferguson
    Mar 14, 2008
    4,914
    1,816
    Upper midwest in a house
    They are not "tubular"
    It's a solid rod turned with a taper. I just made a set for a future project, very easy to make and it's an excellent gear design.
  5. Apr 14, 2009 #5
    rtfm
    rtfm
    rtfm
    Jan 3, 2008
    3,194
    573
    Brisbane, Australia
    Hi,
    Sounds just like the sort of thing I will need for my gear. I have plans for the Sonex, and note that they use titanium rods for their landing gear. I priced this material locally and nearly fell of my chair. 4130 will have to do, thank you very much. I was hoping to use the same dimensions for my project, but since titanium is out of the question, I don't really have much to go on as far as 4130 dimensions are concerned.
    Any rules of thumb on this?
    My little solo Razorback will be very small and light - estimated MAUW less than 500lbs
    Duncan
  6. Apr 14, 2009 #6
    PTAirco
    PTAirco
    PTAirco
    Sep 21, 2003
    3,501
    1,013
    Corona CA
    I had a pair made recently and I am very happy with the work and the service.
    I paid $550 for the pair, custom made to my sketches. After agonizing about the cost for ages, I decided that was it a solution worth the price.
    Mine are a little unusual in that the top part is bent to fit into a horizontal socket (and it fit perfectly I might add) and the lower part is straight. Usual practice is to bend the axle part from the leg, mine use separate welded sockets for the axles. Allowed me to fiddle around with the toe-in and get it right. It worked well, but drilling the upper mounting hole (3/8" dia - it sees a hefty torque load) was torture. The stuff is HARD. It wasn't really feasible to rig the whole thing under a drill press, so I had to do it with a hand-held drill. I pilot drilled with 1/8" and thought I'd creep up on the final size, but it really seemed best to go straight for the final size, minus a reaming allowance. The drill will center much better.
    It took a careful combination of moderate pressure and moderate speed to keep the drill cutting and I had to re-sharpen the bit half a dozen times. A fairly flat point angle worked best.
  7. Apr 14, 2009 #7
    PTAirco
    PTAirco
    PTAirco
    Sep 21, 2003
    3,501
    1,013
    Corona CA
    The steel used is usually 4340, not 4130 and it has to be heat treated to about 220,000 psi to make an effective spring gear. Most places that sell 4130 will also sell 4340.
    Rules of thumb don't work too well on this, but EAA has a spreadsheet that helps you do the calculations.
  8. Apr 14, 2009 #8
    Turd Ferguson
    Turd Ferguson
    Turd Ferguson
    Mar 14, 2008
    4,914
    1,816
    Duncan, from my motorcycle days we sometimes used titanium. I don't recall all the specifics, but we sized parts exactly the same for chromoly and titanium, the difference was titanium clearly had the weight advantage. It's very lightweight, which for an airplane makes it desirable. It was expensive back then as well.
  9. Apr 14, 2009 #9
    PTAirco
    PTAirco
    PTAirco
    Sep 21, 2003
    3,501
    1,013
    Corona CA
    You can't size it the same as steel if you're using it as a spring gear leg. Titanium's modulus of elasticity is about 16,000,000 as opposed to steel's 29,000,000. Aluminium is about 10,000,000, just to give you an idea of the relative stiffness.
  10. Apr 20, 2009 #10
    Super Moderator Staff Member
    Oct 19, 2003
    6,148
    3,455
    I have the EAA spreadsheet if anyone needs it.
  11. Apr 20, 2009 #11
    PTAirco
    PTAirco
    PTAirco
    Sep 21, 2003
    3,501
    1,013
    Corona CA
    Do you also have the accompanying article/sketches? Some of the dimensions asked for are not really well defined. Is "Gear span" from the bend at the axle or from the center line of the tires, for example.
    Is "Gear height" from the ground to - where?
    I searched the EAA magazine archive, but cannot find an article that accompanies this spreadsheet.
  12. Apr 21, 2009 #12
    Oct 19, 2003
    6,148
    3,455
    I don't have the accompanying articles. And you don't need them either. The version of the spreadsheet I have has diagrams on the sheets with the dimensions defined.
    Gear span is lateral distance from gear support to end of spring gear leg. Gear height is the vertical distance from the gear support to the end of the spring gear leg.
  13. Apr 21, 2009 #13
    PTAirco
    PTAirco
    PTAirco
    Sep 21, 2003
    3,501
    1,013
    Corona CA
    In that case, can you forward me a copy of what you have, please?
  14. Apr 21, 2009 #14
    Oct 19, 2003
    6,148
    3,455
    PTAirco,
    PM me your home email, and I will send it there.
  15. Apr 21, 2009 #15
    Oct 19, 2003
    6,148
    3,455
    Oh, and can we get the title of this thread changed to "Wittman type", as in Steve Wittman, the guy who invented this gadget. You know, the field at Oshkosh is named after him, and he has airplanes in the Smithsonian.
  16. Apr 21, 2009 #16
    orion
    orion
    orion
    Mar 3, 2003
    5,800
    135
    Western Washington
    Oops, dyslexic brain function. Sorry about that. I'll try but that might have to be Jake.
    (OK, I fixed my original post and header but the "Re." at each post are still the same.)
  17. Apr 22, 2009 #17
    Oct 19, 2003
    6,148
    3,455
    I feel so much better now!
