Wittman Tailwind modified to meet E-LSA?
mk3041
Sep 13, 2020
I will make somebody a heck of a deal on a Nesmith Cougar project if you want to try for LSA, but you'll have to use a different wing like the Daphne.
Have documentation, but the registration has expired.
Mcmarkwill you please PM me with more information on your Cougar? Thank you.
stanislavz
Aug 21, 2016
952
Lt
However the zenith will take off and land a lot shorter than the Tailwind.
Yes, if engine is still running. But on this topic - if we have boxy fuselage and its centerline is parallel to flying path / zero angle - it is negligibly worse than circular shaped one. If corners are rounded - it is close as it can be, and you make it smaller - better internal space using.
But if you left it sharp cornered and with center line like in Zenith - you have vortexes in wrong space and wrong time. But Zenith cant have it center-lined - its need it to achieve proper aoa for slats to work.
DeanCopley
Feb 27, 2021
1
Lotsa misinformation here, so let me try to clarify (without adding more misinformation...):
* A Sport Pilot can fly *any* airplane that meets LSA speed, weight and other criteria. That includes Standard Category and Experimental, Amateur Built. (Absolutely positive on this one);
* A plane that has been certified to numbers beyond LSA cannot have the paperwork re-done to comply with LSA numbers (pretty sure on this one);
* E-LSA means that the airframe manufacturer has jumped through the hoops to demonstrate that the airframe complies with LSA standards, and has put out a kit so that the airframe can be built outside the factory. And, that kit has to be 100.0% conforming to factory specifications when built, including engine, prop, avionics, etc. However, once built to 100.0% spec and flight tested, it can then be modified. (Positive on this one);
So:
* Join EAA
* Read the regs, they're not that hard to understand.
Be safe, be well!
Ed
Would I be correct in saying that, most of the parameters( stall speed, level cruise speed, empty weight, gross weight) for an EAB are calculated at the end of the build and during the 40hr test flying?Wouldn’t it be at this point that you would determine say the stall speed and then you would know whether it meets the 45kn LSA criteria?
13,118
Calculations of those parameters should be part of the design process. For conventional designs, the predictions should be reasonably close, but actual parameters are proven in testing.
Would note that the very successful Vans RV-12 prototype did not meet LSA parameters (stall speed) and needed slightly more wing area.
stanislavz
Aug 21, 2016
952
Lt
Could some-one clarify me on Szaraz Daphne ? If it have wings from this : Stits SA-7 Sky-Coupe
But fuselage from TW - it weights more, but fligths faster and stalls at lower speed.
Sky coupe
14,734
A nose gear added to a Tailwind will eat about 7 kts off the speed. Tri gear to conventional is not apples to apples. I Ibet the Daphne is probably a hair cleaner anyway. Weights always tend to be better claims than accurate.
With any Wiki spec there has to be a tolerance of whoever put the spec in put all the spec in. Without someone’s real WB and measured speeds to a specific example, it’s all ballpark. You have to push two planes with the same engines across the same set of scales, with the same instruments and accessories to be pound for pound, mph to mph.
stanislavz
Aug 21, 2016
952
Lt
I know. So was my question - you have heavier airplane by more than a margin, more wing area, similar hp, but it top/cruise is faster. Ok, possible due to cleaner shape. But stall is much lower this one is illogical then..
You need more lift / tip vortexes to sustain your heavier airplane in air at same speed.
9,148
LSA sort of Tailwind looking, tri-gear, single place for up to a 300 lb pilot with full fuel, 112 sq' of wing area , 2414 airfoil, 28' 6" wing span, 680 lbs EW, 1100 GW = JMR Special.
