Witold Kasper
henryk
Mar 8, 2010
6,186
krakow,poland
henryk
Mar 8, 2010
6,186
krakow,poland
Henryk,
I sent my modified Kasperwing drawings to Witold Kasper many years ago for his evaluation.
The design featured a higher aspect ratio, single spar, and wing warping for turns.
Here is his reply letter to me:
"Dear Daniel,
After reading your letter I come with the following suggestions:
My initial ultralight Kasper Wing did not have ailerons and was pitch controlled by weight shift.
The minimum speed was zero, did not stall was mushing vertical down.
Maximum speed was 70 mph.
The profile I used was FX05-H-126
I am sending you the data.
The spar should be positioned as is on your Kasper wing.
In order to attain the max. neg. drag at the bottom of the wing, the bottom surface has to be made rough.
The drag decreased by 30%.
The reverse wing warping is not needed.
My tip rudder is sufficient.
The wing could be put in a spin, it was turning very tight.
Sincerely,
W. Kasper"
I am now revising this design and working out the details.
The spar-rib attachment detail is the most difficult design issue right now.
https://www.facebook.com/stephen.j.morris.50/videos/pcb.10214035895805795/10214035887085577/?type=3&theater
-iff the frame like this...
https://www.gleitschirmdrachenforum.de/attachment.php?attachmentid=5399&stc=1&d=1081803209
=10 kg, not heavy !
http://www.reaa.ru/yabbfiles/Attachments/parabeam_001.jpg
http://www.reaa.ru/yabbfiles/Attachments/parabeam_004.jpg
http://www.reaa.ru/yabbfiles/Attachments/PICT4979.JPG
=circa 2 kg/m^2...
Bille Floyd
Sep 26, 2019
516
(very inteesting rigid wing construction!)
YES -- Very interesting indeed !
Thanks for posting a reply, or based on past efforts , i
would not have tried to open it !!
Those D-tubes, and ribs, look a lot like my Exxtacy
and the Atos .
crusty old aviator
Feb 17, 2014
238
Grantham, NH
Wow! Bogdan Wozowicz sure made his wings a LOT lighter than the original BKB, which had heavy sitka spars and plywood skins, and a lot of heavy steel fittings and hardware to hold all that weight together. Did Bogdan retain the original 8-H-12 airfoil?
henryk
Mar 8, 2010
6,186
krakow,poland
http://www.reaa.ru/yabbfiles/Attachments/skrzydlo_kompozytowe.jpg
=yes,"pure" /NACA8-H-12...(water cut).
-it exist china PAEABEAM ,3 mm,but lighter as "auer", circa 0.5 kg/m^2...
iff good proportion of epoxy/vinyl resin,it is possible to make much lighter wing.
now we will try to modify EXXTACY wing into BKB1-A shape (1.22 m chord,NACA8-H-12
airfoil,<30 kg weight).
http://www.reaa.ru/yabbfiles/Attachments/bmw-benz_015_001.jpg
(for aerocar !)
henryk
Mar 8, 2010
6,186
krakow,poland
and the Atos .
http://www.twitt.org/tufts-r.jpg
=VORTEX flow ! (the main adventage...)
=10 kg !!!
BTW=EXXTACY D-spars with ribs and controll wires =24.4 kg (2 x 12.2),
but sail= 6 kg !
flaps + spoilers=5 kg !
I want modyfy sail,like FANTOM (AEROS)...
henryk
Mar 8, 2010
6,186
krakow,poland
https://www.dropbox.com/s/klghoiitqo080z4/IMG_6622.mp4?dl=0
=GIANT Bogdan in action !!!
https://www.dropbox.com/s/htftd6ttj1b2emj/Dym.mp4?dl=0
>230 kG thrust force/ 70 HP...
https://m.facebook.com/story.php?story_fbid=741256036297445&id=100012391659782
=AEROCAR ! (20 HP, 80 kG )
Bille Floyd
Sep 26, 2019
516
[QUOTE="henryk, post: 501093, member:
but sail= 6 kg !
[/QUOTE]
Is that for the 11.4 m (37.4 ft) span wing ; or the
12.2 m (40.0 ft) span ?
And ya still need the control frame , + wires, and control lines.
Bille
henryk
Mar 8, 2010
6,186
krakow,poland
but sail= 6 kg !
Bille[/QUOTE]
=EXXTACY 160, 12.2 m span...
-we are looking into german transparent folien (ORACOVER)+glue
to replace dacron sail!
https://www.oracover.de/film/oracover-air/1
