Will a CarbMate work for 2-strokes?
13brv3
Feb 14, 2018
83
Tellico Plains, TN
Greetings,
Disclaimer, I haven't had much 2-stroke experience.
I own a CarbMate, and I've used it a few times for a 912 carb sync. I recently acquired a plane with a Hirth F-23, and today I decided to sync the carbs. The primer port on the Mikuni looks like it should (?) be a usable vacuum port, so I hooked everything up, zeroed the unit, then ran the engine. Much to my surprise, the indication stayed dead center, and I know that's impossible. I tried pulling one of the carb cables to create an imbalance, and still it stayed in the center, so clearly the reading is incorrect. Next I removed a hose from the unit, and the indication went fully to one side as you'd expect. I can also feel pulses on the disconnected line.
Question is- Should this work, or is this a 4-stroke only device?
Thanks,
Rusty (putting on my 2-stroke dunce cap)
poormansairforce
Mar 28, 2017
940
Just an Ohioan
Greetings,
Thanks,
It's a twin that has a common crankcase. There will be no difference between the carbs. Think of it as a big single with better balance. Using 2 smaller carbs gets better idle, etc.
4,563
I seem to remember a separate port I had remove a set screw and screw a barb fitting to hook up a mercury balancer on my motorcycles. Not familiar with that engine or that sync tool but I would think if the slides or throttle plates are not letting in the same amount of air into the engine your tool should show that.
n3puppy
Jun 25, 2019
138
Like poormansairforce said - wont work on the F23 because common crankcase equalizes pressure both sides.
Would work on a more typical 2 stroke like a Rotax 503 Etc. .
Need a tool that measures on the inlet side of the carb not the back side like the primer port.
The classic Uni-Syn (and current copies) should work on the F23 opposed twin
