When lightning strikes
Discussion in 'Rules and Regulations / Flight Safety / Better Pil' started by autoreply, Jan 25, 2011.
  1. Jan 25, 2011 #1
    autoreply
    autoreply
    autoreply
    Moderator
    Jul 8, 2009
    10,732
    2,552
    Rotterdam, Netherlands
  2. Jan 25, 2011 #2
    Lucrum
    Lucrum
    Lucrum
    Jun 10, 2008
    956
    189
    Canton, GA
    I've been hit before in flight.
  3. Jan 26, 2011 #3
    Monty
    Monty
    Monty
    Jul 15, 2010
    1,294
    496
    Fayetteville, AR / USA
    I remember when this happened. I was just learning to fly gliders. We got pictures of the remains of the glider in emails that circulated the gliding community at that time. The guy who was running the glider operation, and was the tow pilot where I was learning to fly, just happened to be one of the formost experts on lightning protection for aerospace vehicles in the US. It was nice to have an expert to explain things. For instance the way the control rod was malformed is caused by the rise and fall of magnetic fields caused by the lightening bolt. I've been in an airplane that was hit by lightening, but that was an airliner and scary enough...I've also had a canopy come open on tow in a glider....can't imagine the two things combined and the airplane disintegrating at the same time...must have been quite a ride.
    Both of them performed quite well given the circumstances I'd say......
  4. Jan 26, 2011 #4
    JamesAero
    JamesAero
    JamesAero
    May 10, 2010
    46
    0
    Salem, OR
    I was flying a Cessna 414 that was hit by lightning over the Cascades and while it scared the hell out of me for a split second it had no ill effects on the aircraft. That is one huge advantage of a metal airframe. Now that I'm building a composite homebuilt it is frequently in the back of my mind that I won't have that form of protection.
  5. Jan 26, 2011 #5
    Monty
    Monty
    Monty
    Jul 15, 2010
    1,294
    496
    The tow pilot...Joe..managed to convince me that plastic airplanes and static electricity do not mix well. If you remember the early pictures of the space shuttle punching through a cloud layer...you will note that they did not do that later in the program...Joe is the reason. As Joe related, the vehicle was not safe WRT lightning. Joe had lot's of neat stories. He had worked primarily with EMP and lightening protection during his career.
    For those with plastic airframes, you may find THIS interesting.
  6. Jan 26, 2011 #6
    WonderousMountain
    WonderousMountain
    WonderousMountain
    Apr 10, 2010
    1,853
    193
    Clatsop, Or
    Does that mean a plastic plane should have no conductive parts to avoid lightening failure modes?
    Building an all rubber plane will be difficult:tired:
    off topic,
    Wonderous Mountain
  7. Jan 26, 2011 #7
    autoreply
    autoreply
    autoreply
    Moderator
    Jul 8, 2009
    10,732
    2,552
    LIGHTNING STRIKE PROTECTION from Aircraft Spruce
    I guess this is one of those things where neglect plays a big role. Pilots easily forget the dangers (microburst, turbulence, turning wind, lightning) and I've learned my lesson too. 3000 fpm ain't much fun if you can't stop the climb of the aircraft...
  8. Jan 26, 2011 #8
    Mac790
    Mac790
    Mac790
    Jun 22, 2008
    1,529
    19
    Poznan, Poland
    Ok, so what is an industrial approach to that problem, I'm talking about new Boeing DreamLiner, not to mention all those "plastic" UAV's. I didn't notice that "lighting protection grid" on them, here is better source for those grids than that posted by Jarno Expanded Metal - Expanded Metal Foil - Expanded Metal Mesh - Expanded Plastic - Dexmet Corporation . What's a point of making extremely smooth surface, and next apply that grid over it?
    Lighting strike protection for carbon bird http://www.dexmet.com/1_pdf/LSP%20for%20Carbon%20Fiber%20Aircraft.pdf
    Seb
  9. Jan 26, 2011 #9
    autoreply
    autoreply
    autoreply
    Moderator
    Jul 8, 2009
    10,732
    2,552
    Not the slightest clue, but maybe they isolate the mesh with an (epoxy/vinylester) spray?
    Mold=>gelcoat=>glass/kevlar=>mesh=>glass/kevlar=>carbon=>foam=>carbon
    Then, the gelcoat and outer layer still vaporizes, but your structure remains in tact. Afaik, this is what's used in small aircraft.
  10. Jan 27, 2011 #10
    Othman
    Othman
    Othman
    Aug 23, 2004
    355
    4
    Ottawa, ON, Canada
    This is a very good topic. Thanks for starting it Autoreply.
    The aluminum or copper mesh material is quite thin (.002" and up), less than a ply of glass. It is layed up in situ with the glass plies in the laminate (co-cured). The mesh is located at the outer most surface of the laminate just under a surfacing ply (a lightweight glass fabric). If the laminate is carbon fibre with an embedded aluminum mesh, then an isolation ply of glass should be used between the two materials to prevent galvanic corrosion.
    You can still achieve a smooth surface in the end. The main problem is when you have compound curves. In that case there are other lighting strike protection options such as flame spray coating or aluminized fabrics.
    See the following resources for more in depth information.
    Aircraft Lightning Protection Handbook
    This was later made into the DOT/FAA/CT-89/22, LIGHTNING PROTECTION HANDBOOK. I have a copy of the PDF but it is too large to post.
    A similar handbook was produced under the AGATE program focussed on General Aviation applications.
    http://www.niar.wichita.edu/agate/Documents/Lightning/WP3.1-031027-043.pdf
  11. Jan 27, 2011 #11
    Monty
    Monty
    Monty
    Jul 15, 2010
    1,294
    496
    No, it means that you should not fly in your plastic plane near convective sigmets.....If you do make sure you have metal mesh in the top layer of the laminate...and hope you don't intersect a main channel or worse yet, a positive stroke.
  12. Feb 4, 2011 #12
    Orwasi
    Orwasi
    Orwasi
    Dec 18, 2009
    17
    0
    Sydney, Australia
    Excuse my ignorance, but what happens to that thin mesh during a lightning strike? Is it damaged in some way, like a fuse exposed to excessive current and/or voltage? If it is damaged, replacing it (to maintain the protection for the airplane) sounds like an expensive exercise.
  13. Feb 11, 2011 #13
    teknosmurf
    teknosmurf
    teknosmurf
    Aug 17, 2010
    133
    1
    Queen Creek, AZ
    I doubt much would happen to the mesh assuming there is a relatively effective discharge path (static rods, etc), and there is little/no path of least resistance (exposed mesh somewhere, etc). I would expect the mesh to pretty much spread the electrons over the a much larger surface area, thereby reducing the amount of power going throuh any specific location.
    As I understand it, aircraft rarely take a direct hit from an actual lighting bolt. While the following description is very similar to the way a lightning bolt is created, it has some important differences. Usually what is described as a lighting strike is just a build up of electons as the plane moves through the air/clouds (much like dragging your feet on the carpet). Because "plastic airplanes" are made of insulated material, the charge builds up to a sufficient level before discharging into the surrounding atmosphere (like touching the doorknob). By wrapping the plane in the mesh, and putting static rods on the back of your wings, you are effectively putting a metal glove on your hand with a wire to the ground, and allowing the charge a path to disipate before it ever becomes a "lightning bolt". Think of it as replacing the air between your finger and the doorknob with a piece of metal. As you drag your feet the electrons are discharged through the metal directly to the doorknob so there is never a spark (or lightning bolt) to begin with.
  14. Feb 11, 2011 #14
    12,039
    3,469
    The strike is not what does the damage it is the exit of the power. The planes I am familiar with are SAABs and CRJs. All the structures are suppose to be bonded so the potential is the same everywhere. When lightning hits, you want it to not find a place to exit until it gets to the dischargers/ static wicks. If it finds a place that is not bonded, that is when the damage happens. The composite parts have a foil or a fine mash between the structural and visual parts of the composite part. When installed it ends up being bonded(grounded) the adjacent areas. The biggest damage I have seen has been a composite fairing behind the wing on a CRJ burn all its resin out so it was just a giant cloth flapping in the breeze, seen a wing tip do that too, and on the metal side, CRJ melted a hole I could put my arm into. Most normal strikes you can see it skip down the fuselage, blowing out rivets every 5 feet or so. A local Cirrus got struck and it cost him a lot of money before Cirrus was happy with the repair; they dont have the mesh.
