Rrtaya_Tsamsiyu
Does anyone know what type of radio was used in the WW2 scout plane, the L-4 Grasshopper? i haven't been able to find any info on this
I know this is an old thread, but I just had to answer.bmcj, i'm hoping to find one working on the WW2 channels. their are already WW2 radios used in the reenactments i've been to, as far as i know there's nothing official in the US that uses those channels anymore. im pretty sure all of the WW2 frequencies are lower than the ones used now. As far as weight, i would usually only have it during the reenactments.
:roll:...
To convert from Megacycles to Megahertz... Megahertz = Megacycles * sqrt(4)/2:gig:
Just noticed the crank above his left shoulder. That, I think, is the HF antenna. It would be retracted for landing and cranked out in flight.
You're asking to get "megahert'.It is a bit fuzzy, but I read the crystal frequency as 5495.634 MHz...uh, sorry. That would be 5495.634 MCs in WW2.
Ooops! :emb: My bad! The crystal frequency would be 5495.634 Kc not Mcs. The conversion formula to kHz is the same as that for MHz, by the wayBack then, it would have been kc (khz) not mc/mhz. I don't think anything over 10mhz was in general use back then.
And the source is listed as "Pilots Flight Operating Instructions, Army Model L-2, L-2A, L-2B, and L-2M Airplanes," T.O. No. 01-135DA-1 1944, pp. 18-20. So if you have or can find the "Pilots Flight Operating Instructions, Army Model L-4..." then you should be able to identify the exact radio installation for each model of L-4.Avionics
Learadio AMR-12 Receiver & AMT-12 Transmitter (L-2); RCA AVR-20A (L-2A); RCA AVT-15A or AVT-112 (Some L-2A, L-2M); Slipstream powered generator: Champion Model W612-6V
