What is the Best Epoxy Glue to Glue 6061 Tubes?
Discussion in 'Tube and Fabric' started by Armilite, Mar 12, 2015.
  1. Mar 12, 2015 #1
    Armilite
    Armilite
    Armilite
    Sep 6, 2011
    2,934
    228
    AMES, IA USA
    What is the Best Epoxy Glue, to Glue 6061 Tubes in 1.0" to 3.0"? In .058" to .080" wall.
  2. Mar 12, 2015 #2
    kent Ashton
    kent Ashton
    kent Ashton
    Aug 15, 2008
    714
    201
    Concord, NC
    Perhaps ProSeal will work for you. Epoxy generally makes a weak, fragile bond to aluminum and any stress will break the bond. Pro seal is rubbery and more forgiving but neither is as secure as rivets or welding
    cheapracer likes this.
  3. Mar 12, 2015 #3
    8,877
    5,729
    What is the application?
    SVSUSteve likes this.
  4. Mar 12, 2015 #4
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,059
    3,327
    Australian
    I did lots of tests recently, the conclusion is rivets as primary with the epoxy only in a secondary joint stabiliser role. I'm with Kent above, a slightly more flexible product is preferable (again, in secondary role) and my choice is one of the "No Nails" type adhesive products.
    There is no magic epoxy for metals unless you are big time, car companies such as GM, Benz and Lotus etc use bonding without fasteners or only anti peeling fasteners, but they spend millions for 'exclusive to their needs' products and make use of curing ovens in some cases.
  5. Mar 12, 2015 #5
    BoKu
    BoKu
    BoKu
    Aug 16, 2013
    2,178
    2,704
    Douglas Flat, CA
    Really. The question is pretty much meaningless without knowing what the joint geometry is.
    There have been a few places where I needed a high-strength bond between 6061-T6 tubing and a precision-fitted sleeve. I used Hysol EA9430.
    Thanks, Bob K.
    SVSUSteve and BJC like this.
  6. Mar 12, 2015 #6
    5,751
    4,620
    You will find the best adhesive is called AN470 :)
    dcstrng, SVSUSteve, rv6ejguy and 2 others like this.
  7. Mar 12, 2015 #7
    Rconc
    Rconc
    Rconc
    Jun 29, 2007
    12
    3
    Winston Salem, NC
    I am not familiar with EA9430 but 3m 2216 is a good epoxy that does retain some flex. Metal bonding requires surface prep and primers to protect the bondline. I have heard of a primer EC3901 that can be used with 2216 but it would require you research it.
    rv6ejguy likes this.
  8. Mar 12, 2015 #8
    Norman
    Norman
    Norman
    Nov 29, 2003
    2,877
    902
    Grand Junction, Colorado
  9. Mar 12, 2015 #9
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,059
    3,327
    Australian
    To be noted ..
  10. Mar 14, 2015 #10
    TJay
    TJay
    TJay
    Jan 18, 2014
    201
    130
    Maurice IA
    I used Hysol 9460 for everything on my kitfox, it works great, I have found if you are sticking it to 4130 you should prime first but for aluminum and wood it holds way better to bare surface.
  11. Mar 16, 2015 #11
    Armilite
    Armilite
    Armilite
    Sep 6, 2011
    2,934
    228
    AMES, IA USA
    Part103 Ultralight. Maybe also use for Carbon Fiber Tubing.
    Years ago, I watch a TV show on Adhesives. The guy took two 1/4" thick Steel Plates, about 3" x 9" and squirted some Epoxy Glue on the two, about half & half, and then layed them together. After they cured, don't remember how long that was, but they were placed in a Hydraulic Machine that pulled on the Two Plates Lenght wise till they came apart. The metal tore in half before the Glue part came apart!
    Months after that show, I bought some cheap 2500lb Walmart 2 part Epoxy Glue. I had a Military Generator with a metal part that was glued on the Plastic Type Gas Tank for the locking gas cap. I took that Epoxy Glue and spread it around the pieve with a Q Tip, and put it back on the Tank. I wanted the Cap to make the chain tight when locked on, so I also put the Cap on. I let it dry over night. The next day I went to turn the Cap off, and I couldn't turn it. I used a Big Pipe wrench and couldn't turn it. So I put a 3' piece of tube over the handle, and it took all I had to get it broke loose. I was 6' 290lbs then. When I got it broke loose with the cheater Tube, I looked under the Cap, two holes about a 1/8" allowed Expoxy to leak thru to bond the two parts together. That impressed me on it's holding strenght.
    So I had the idea then, why not Epoxy Glue the Tubes for a Part103 Airframe, like PVC Tubes. Use either 6061, or Carbon Tubing. And use Rivets where needed to save the weight of all the Bolts & Nuts & Washers. I haven't found any good connectors to try it yet.
    Rich
  12. Mar 16, 2015 #12
    Jay Kempf
    Jay Kempf
    Jay Kempf
    Apr 13, 2009
    3,531
    865
    Warren, VT USA
    Actually Lotus and Panoz have gone to adhesive suppliers that also make the products available retail. Lotus used an oven cure two part injectable which is probably not practical for homebuilt projects but the adhesive that Panoz used was developed by a little company in NH but now is available through ITW Plexus. The adhesive is a Methylcrylate. I have used this stuff on raw aluminum without prep and it's performance was impressive. This is the future of aluminum structures. You have to learn to design bond area in the right directions and with the right area and protect against peel but those are fairly straightforward things to learn. There are several blends of this stuff for viscosity and speed of cure. It can be injectable or just run a bead and clamp sort of applications. When I was experimenting with this stuff we had to design a pressure and volume dosing gun for injecting joints that were designed to be done in one push of the button for a production application. Very promising. 3M has been experimenting with high density foam double stick tapes for joining panels as well. That shows some real promise as well because you can form and then coat a panel and then attach it without scratching or penetrating the coating. And the performance is pretty amazing for tensile, peel and shear.
  13. Mar 16, 2015 #13
    BoKu
    BoKu
    BoKu
    Aug 16, 2013
    2,178
    2,704
    Douglas Flat, CA
    Many epoxy formulations are good for 2ksi, and some high-strength blends are good for 4.5ksi. Given 27 square inches of bond area, with the good stuff you ought to get around 120k lbs of tensile capacity. Depending on how the coupons are shaped and assembled, it's not beyond reason that you'll break part of the coupon.
    What epoxies generally suck at is T-peel. Given a T coupon made of two lightweight aluminum L shapes glued back to back, it's typical to see 5 lbs per linear inch, with the very best formulations going to 60 lbs per linear inch. So, best to avoid loading epoxy joints such that prevailing forces can peel them apart.
    It's all about the joint geometry. Butt joints are a non-starter; there's just not enough bond area to get anywhere near the strength of the tubing you're joining. Scarf joints would be so long as to be unwieldy. Sleeve joints like with PVC tubing, as you suggest, would be best. But in a typical airframe there are dozens if not hundreds of different joint geometries to address.
    Thanks, Bob K.
  14. Mar 16, 2015 #14
    5,874
    1,494
    Acrylic or polyurethane works far better on aluminium than epoxy
  15. Mar 16, 2015 #15
    Lucrum
    Lucrum
    Lucrum
    Jun 10, 2008
    955
    188
    Canton, GA
    I'm no expert in this area and I don't mean to rain on anyone's parade.
    But the idea of aluminum tubes and epoxy for anything bearing a load gives me the willies.
  16. Mar 16, 2015 #16
    8,877
    5,729
    If you are not familiar with Leo Loudenslager's efforts to build the lightest aerobatic monoplane possible, with some wild aerodynamic comtrols see this video:
    https://m.youtube.com/watch?v=-ZTFnZV5NU8
    Skip to 1:40 to see the titanium cluster, carbon tube truss.
  17. Mar 16, 2015 #17
    Jay Kempf
    Jay Kempf
    Jay Kempf
    Apr 13, 2009
    3,531
    865
    Warren, VT USA
    And it should. But, and this is a significant one, if you do the proper prep/etch of the surface and use the correct epoxy and match the alphas of the two bonded materials it can be done. Alex Strojnick did just that in the S-2 spars and other parts of the design. Highly loaded. There are way better ways to do that now but even 20+ years ago people were way out of the box doing bonded structures. The BD-4 had non structural skin put on with rivets every 6 or so inches and contact adhesive and it worked fine. Design the bond properly, prep the materials properly, don't overload the adhesive properties and it will work.
  18. Mar 16, 2015 #18
    Lucrum
    Lucrum
    Lucrum
    Jun 10, 2008
    955
    188
    Canton, GA
    I hadn't seen that one before
  19. Mar 17, 2015 #19
    Armilite
    Armilite
    Armilite
    Sep 6, 2011
    2,934
    228
    AMES, IA USA
    Dragon Plate use's these Epoxy Glues below for Carbon Tube parts. Some below, I see have also been reccomended above also for 6061 Tube. My idea, is to have something that sets up fast like PVC Glue does. Just apply, insert, and line it up, hold it in place for a few minutes, then set done and let dry over night. If applying some Heat, helps it cure faster, maybe put in makeshift electric oven. But I can wait 24hrs. Then Glue smaller assemblies to make bigger assemblies.
    For a Part103 Type Airframe, we only probably need, a Splice for Joints, a 90 Elbow, a 45 Elbow, a Tee, a Four Way cross, maybe a X Type Cross, a End Plug, a Spar Sleeve Tee, like one part 2.5" with a 1" small part for making Wings. I'm sure there are a few others, but not that many.
    Rich
    [TABLE="width: 100%"]
    [TD="class: productRow1, bgcolor: #F0F0F0"]Double/Bubble Black Regular Setting Epoxy Adhesive
    HARDMAN Regular-Setting Epoxy is a two component, room temperature cure epoxy system designed to set in 45 minutes in a thin (10 mil) film. 3.5 gram foil pack.
    More Info[/TD]
    [TD="class: productRow1, width: 80, bgcolor: #F0F0F0"][​IMG][/TD]
    [TD="class: productRow1, width: 100, bgcolor: #F0F0F0"]$1.50 USD
    [​IMG]
    [/TD]
    [TD="class: productRow2"]Double/Bubble Orange High Peel Strength Epoxy Adhesive
    HARDMAN High-Peel-Strength Epoxy is a semi rigid, two component structural epoxy adhesive with a 3 hour work time. Excellent combination of shear strength and peel strength. 3.5 gram foil pack
    More Info[/TD]
    [TD="class: productRow2, width: 80"][​IMG][/TD]
    [TD="class: productRow2, width: 100"]$1.40 USD
    [​IMG]
    [/TD]
    [TD="class: productRow1, bgcolor: #F0F0F0"]3M Scotch-Weld Epoxy Adhesive 2216 B/A Gray Tube Kit
    Highly Flexible, Two-Part Adhesive Kit highly recommended for DragonPlate bonding. Available tube or pint kit size.
    More Info[/TD]
    [TD="class: productRow1, width: 100, bgcolor: #F0F0F0"]$52.50 USD
    [​IMG]
    [/TD]
    [TD="class: productRow2"]3M Scotch-Weld Epoxy Adhesive DP110 Gray 50ml Duo-Pak
    3M Scotch-Weld Epoxy Adhesive DP110 is a flexible, two-part epoxy. 1:1 mix ratio, 10 minute work life and handling strength in 20 minutes. Dispensed with a 3M Scotch-Weld EPX Plus II applicator. 1.7 oz/50ml
    More Info[/TD]
    [TD="class: productRow2, width: 100"]$24.60 USD
    [​IMG]
    [/TD]
    [TD="class: productRow1, bgcolor: #F0F0F0"]3M Scotch-Weld Epoxy Adhesive DP190 Gray Duo-Pak
    3M Scotch-Weld Epoxy Adhesive DP190 is a gray, two-part epoxy. 1:1 mix ratio, 90 minute work life and handling strength in 12 hours. Dispenses with 3M Scotch-Weld EPX Plus II applicator. 1.7 oz/50ml
    More Info[/TD]
    [TD="class: productRow1, width: 100, bgcolor: #F0F0F0"]$24.60 USD
    [​IMG]
    [/TD]
    [TD="class: productRow2"]3M Scotch-Weld Epoxy Adhesive DP420 Off-White 37ml Duo-Pak
    3M Scotch-Weld DP420 is a 2-part off-white epoxy adhesive with outstanding shear and peel adhesion, very high levels of durability, controlled flow, a 2:1 mix ratio, 20-30 minute worklife, and develops handling strength in 1-2 hours. 37ml
    More Info[/TD]
    [​IMG]
    [/TD]
    [TD="class: productRow1, bgcolor: #F0F0F0"]3M Scotch-Weld Epoxy Adhesive DP420NS Black 37ml Duo-Pak
    3M Scotch-Weld Epoxy Adhesive DP420NS is a black, non-sag, toughened, two-part epoxy adhesive. 2:1 mix ratio, 20 minute work life and handling strength in approximately 2 hours. Requires EPX Plus II applicator gun to dispense. 37ml
    More Info[/TD]
    [TD="class: productRow1, width: 100, bgcolor: #F0F0F0"]$25.45 USD
    [​IMG]
    [/TD]
    [TD="class: productRow2"]3M Scotch-Weld Epoxy Adhesive DP460NS Off-White 37ml Duo-Pak
    3M Scotch-Weld Epoxy Adhesive DP460NS is a toughened, non-sag, two-part epoxy. 2:1 mix ratio, 60 minute work life and handling strength in 4 hours. Requires 3M Scotch-Weld EPX Plus II applicator gun to dispense. 37 mL
    More Info[/TD]
    [TD="class: productRow2, width: 100"]$26.50 USD
    [​IMG]
    [/TD]
    [TD="class: productRow1, bgcolor: #F0F0F0"]3M Scotch-Weld Epoxy Adhesive EC-2216 Gray 43M Duo-Pak
    3M Scotch-Weld Epoxy Adhesive EC-2216 is a gray colored, flexible, two-part epoxy. 2:3 mix ratio, 90 minute work life and handling strength in 10 hours. Dispensed with 3M Scotch-Weld EPX II Plus Applicator. 43 mL
    More Info[/TD]
    [TD="class: productRow1, width: 100, bgcolor: #F0F0F0"]$18.75 USD
    [​IMG]
    [/TD]
    [TD="class: productRow2"]3M Scotch-Weld Low Odor Acrylic Adhesive DP810, black 50ml Duo-Pak
    3M Scotch-Weld Low Odor Acrylic Adhesive DP810 is a toughened, two-part black acrylic adhesive. 1:1 mix ratio, 10 minute work life and handling strength in 20 minutes. Dispensed with 3M Scotch-Weld EPX II Plus Applicator. 50ml
    More Info[/TD]
    [/TABLE]
  20. Mar 17, 2015 #20
    Armilite
    Armilite
    Armilite
    Sep 6, 2011
    2,934
    228
    AMES, IA USA
    What a little glue scare ya? :) Many people climb into a Part 103 Airframe, held together with Plastic Standoffs & Bolts or Rivets, and use thin wall 6061 tube, some even with thin cables holding some parts together. 50% of them scare me.
    Maybe some good test could be done, with some piece's of 1.0" 6061, Epoxy Glued on one end, with the standard way on the other, and see which fails first!
    I have seen some 1/4" Steel Plate, about 3" x 9", Epoxy Glued, half & half together, roughly 3" x 3" area, and put in a Hydraulic Machine that pulled on them till the part failed. The 1/4" steel plate tore in half, before the Glue Joint broke. Is that Glue available today, to the general public, I don't know. I have had some dealings with Walmart cheap Epoxy Glue, 2000 or 2500lb that impressed me. More and more stuff is Glued today.
