Aviator168
Title says it all.
Thnx. That pretty much says there is no limit.The highest that you can go is dependent on airspace, but the class E limit would be 17,999 MSL
On a practical note, no, since it's doubtful many powered Part 103 UL's can get to 17,999'MSL. But UL sailplanes most certainly could, and 17,999'MSL would be the top limit on legal altitude for any legal UL operations in US airspace.Thnx. That pretty much says there is no limit.
Sure. I thought there was an altitude limit like a few thousand feet; some thing lower than the LSA limit.Remember that in practice, although the Ultralight might make, (although unlikely the engine wood have enough "puff" to get you there) 17,999 feet and survive, it is very unlikely you, yourself would survive the rather slow final accent much above 12-15,000 feet, unless you have an oxygen supply:-(
A transponder is required above 10,000 MSL (48 states) for most* aircraft. Not sure if this applies to ultralight "vehicles".
*excluding, gliders, balloons and aircraft without engine driven electric system.
That's the beauty of Part 103. So long as you don't put other people in danger, you're free to be as stupid and reckless as you want. And flying an already marginal ultralight to 17,999'MSL surely qualifies...Sure. I thought there was an altitude limit like a few thousand feet; some thing lower than the LSA limit.
SHUUSHHHH!!! Don't let the FAA know they overlooked another restriction for Part 103!I thought there was an altitude limit like a few thousand feet; some thing lower than the LSA limit.
Put bungie hooks or dzus fasteners on them and call them "luggage".Once I put those equipment in, I am probably be over the empty weight limit.
Yeah, right!SHUUSHHHH!!! Don't let the FAA know they overlooked another restriction for Part 103!
Hahaha. I rather install a BRS.Put bungie hooks or dzus fasteners on them and call them "luggage".![]()
Realistically, this is effectively a requirement to stay below 18,000', but if one could get permission from ATC (unlikely), one could legally fly an ultralight much higher, but legally it's no different from obtaining permission to operate in class B (rare), C (almost as rare), or D (often allowed) airspace.§103.17 Operations in certain airspace.
No person may operate an ultralight vehicle within Class A, Class B, Class C, or Class D airspace or within the lateral boundaries of the surface area of Class E airspace designated for an airport unless that person has prior authorization from the ATC facility having jurisdiction over that airspace.
depends on how much of a hurry you are in.All these tricks are cool. But still, there is a speed limit, which make an UL can't be used for serious traveling.
