henryk
Mar 8, 2010
7,311
krakow,poland
My proposal did not include springs.
-in youth we have bad L/D hanggliders...for longering fly time/distance
we was "pumping" wing via trapetze.= weavy trajectory needs smaller energy as strait one !
=trajectory for JANTAR glider...(circa 100 km/h)
John.Roo
Oct 8, 2013
1,861
Letohrad / Czech Republic
Comparison of top ICE Paramotor to latest Electric Paramotor is interesting....
If Electric range could be doubled to 2 hours,probably everyone would fly electric.....electric has so many advantages!
Compare top electric and gas paramotors | OpenPPG
I wonder how much power paraglider needs to stay in horizontal flight....
According to specification of Open PPG is max. power of motor 25 kW.
Personally I don´t like to take 25 kW of power from 4,4 kWh battery...
Weight is 12.7 kg (28 lb) for motor installation + 20,5 kg (45,2 lb) for 4,4 kWh battery.
So on your back is 33-35 kg of extra "propulsion weight".
Honestly I don´t beleive you can takeoff and fly 60 minutes with paraglider with 4,4 kWh battery...
Takeoff and climb will request a lot of battery capacity, however could be a "sustainer" - when you "takeoff" from top of hill and you need to seek for thermals during horizontal flight 👍
EzyBuildWing
Sep 23, 2009
606
Sydney NSW Australia
Bahamas Paramotoring.....real-cool......this pilot transports his complete flying-machine to the launch-area, in an electric bicycle-trailer.......!!!!
This is the first flying-machine I've seen that you can store in you garage at home then tow it in a bicycle-trailer to your local airport and take-off....
Scenery in this proximity-soaring vid is breath-taking (absolutely stunning)....!!!!
See also his other incredible vid: Getting Stranded on a Desert Island.
John.Roo
Oct 8, 2013
1,861
Electric airplane ELECTRON from Australia....
Looks "a little bit" like Millenium Master - only with "straight" elevator :cool:
Australia... beautifull coutry with a lot of sun and legendary gliding conditions.
Pitty that new Australian projects looks more like "normal" tandem seat airplane....
"On the MGM-Compro web site, the motor is priced at 7,875 euros (9,065 U. S. dollars). At current market prices, lithium-ion batteries cost about $137 U. S. per kilowatt-hour. The pack would cost $6,302 at those prices. Adding costs for a battery management system and associated cables could mean a total powerplant price under $20,000."
Sorry but 6 302 USD is far too optimistic price for 46 kWh battery :D
Nevertheless - lets watch this project. I wish to ELECTRON team good luck! 👍
John.Roo
Oct 8, 2013
1,861
Hello!
Winter is comming so it is more time to dream :D
Before I already mentionned idea of "as light as possible" and "affordable" electric one seater with power 15-20 kW and small 6-7 kWh battery (= 1x takeoff and endurance arround 60 min + small reserve).
Draft one - typical "FES like" way.
Draft two - "Windex like" way. Retractable pylon is theoretically possible (even in draft one) however than is problem with place for rescue system installation. I mentionned this version anyway ;)
Draf three - "EXEL like" way = pusher config. To keep front profile small it could be short pylon retractable.
So here are 3 drafts. Each has some advantages and disadvantages.
Performance is not most important however each concept has L/D better than 1:30.
Comments on what concept you would most like (and why) are welcome 👍
henryk
Mar 8, 2010
7,311
krakow,poland
here are 3 drafts.
+ 4-th "draft"= modyfied STEMME (ELFIN)
-NO mooved nase, only conical semiring,when drifted back=open place for CRpropellers.
-first propeller 3-blade, second 2-blade (lower interference noise).
-circa double RPM (light,cheap) motor in DIFFERENTIAL mode (autrunner or innrunner),
NO gear ,
only sliding contacts !
-good aircooling (big air inlet + ROTATING stator).
=NO need in circular nase (universal).
PS=clean fuselage in soaring phase (max L/D) !
jedi
Aug 8, 2009
3,236
Hello!
I like Draft one - typical "FES like" way. Prop in front.
A quick and simple start when needed. Can see that all is well and working. Possible cockpit heat (limited) from motor cooling air. Thrust on centerline is the biggie.
Second choice is Draft two - "Windex like" way. Still a quick and easy start. Clean aerodynamics. But long run from batteries to motor.
ypsilon
Mar 1, 2016
307
Austria
FES - Type, anytime.
Advantage: (Structurally) Simple, Aerodynamically (clean in the sense that the prop doesn't need to chop turbulent air), quickly and easily deployed (This is very important in real-life gliding. Outlanding accidents usually happen with motorgliders (mostly sustainers) - and there is a reason for that).
Disadvantage: Little clearance when launching on grass, which probably means that you'd go for a retractable gear, which adds complexity and weight again.
henryk
Mar 8, 2010
7,311
krakow,poland
="suck" is not right word for fenomenon of propeller thrust generation...
-it is no possibility to pull air (N2 +O2 molecules),
they have big kinetic energy (E=mV^2= kT) , circa 150 kJ /m^3 !
=the only forces between molecules are push one.
-propellers are nonsymmetrical "vacuum pumps",
but NO turbomolecular (very high RPM, >50 000 /min)
blane.c
Jun 27, 2015
6,150
capital district NY
Apparently "my humor" doesn't transcend the language barrier. "Suck" wasn't meant literally, but meant as humor. AKA "it sucks".
John.Roo
Oct 8, 2013
1,861
Thanks for interesting opinions.
According to installation seems FES simpliest, however I see 2 main problems.
1) electric motor lifetime - on typical grass airfield is a lot of dust (small stones, grass etc.) and in this type of installation is motor very low and there is high risc that after few year of intensive operations it can be a problem. Could be solved with liquid cooled motor.
2) as mentionned - lower gound clearance = smaller prop = lower efficiency during takeoff and higher noise. Typical FES prop diameter is smaller than 1 m. If would be larger it means higher undercarriage. Modern glider profiles don´t like high angle of attack so until tail of glider goes up you can have problems with ailerons efficiency. Really not nice during takeoff with crosswind (personal experience).
Plus one safety problem... FES instalation needs to install power lines really near (arround) pilot seat. Can be done perfectly, however during ground impact is pilot zone absorbing deformation = higher risc of power wiring damage. Don´t forget that carbon is well leading electricity. To achieve lower weight of power wiring we typically try to reduce current. However "affordabe" battery voltage is arround 100 V (24S fully charged) = still 150-200 Amps during takeoff....
Just to thing about ;)
