Discussion in 'Soaring' started by John.Roo, Dec 5, 2013.
  1. Mar 28, 2019 #301
    copec
    copec
    copec
    Aug 3, 2015
    37
    6
    Santa Clara, UT
  2. Mar 28, 2019 #302
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,850
    480
    krakow,poland
    copec likes this.
  3. Aug 7, 2019 #303
    John.Roo
    John.Roo
    John.Roo
    Oct 8, 2013
    266
    183
    Letohrad / Czech Republic
    Hello!
    Actually we have flown over 50 hours - mostly with two pilots aboard :)
    Best regards!
    Martin
    P.S.
    Most of you probably know but....
    It is 360 video - you can move / zoom your view with mouse. It works for example with Firefox or Chrome.
    emir_82 and rdj like this.
  4. Aug 7, 2019 #304
    John.Roo
    John.Roo
    John.Roo
    Oct 8, 2013
    266
    183
  5. Aug 7, 2019 #305
    John.Roo
    John.Roo
    John.Roo
    Oct 8, 2013
    266
    183
    henryk likes this.
  6. Aug 7, 2019 #306
    John.Roo
    John.Roo
    John.Roo
    Oct 8, 2013
    266
    183
    And a little bit of history....
    110 years ago Luis Bleriot did his historical flight over English Channel (La Manche). To honor his memory we did 25. of July the same flight with electric Phoenix. Just a few differences - we flew over land, I had co-pilot (= two persons aboard), we did it much faster and at the end we had enough capacity in batery to make it two times more - in other words would be possible to make 6 times Channel crossing on one recharge.
    https://scontent.fprg1-1.fna.fbcdn....=cc6e8c930612a555065935f3b22a459e&oe=5DA01747
    https://scontent.fprg1-1.fna.fbcdn....=84105fa1d06dcc60d1a07bdd2a34df7d&oe=5DE570F5
  7. Aug 7, 2019 #307
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,850
    480
    krakow,poland
  8. Aug 8, 2019 #308
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,850
    480
    krakow,poland
    e-biking ?
  9. Aug 9, 2019 #309
    litespeed
    litespeed
    litespeed
    May 21, 2008
    1,550
    320
    Sydney
    No that is a Airbike.
    Good way to test rather than a static setup.
    Love the hair.
  10. Sep 6, 2019 #310
    John.Roo
    John.Roo
    John.Roo
    Oct 8, 2013
    266
    183
    Hello!
    Last weekend was very interesting meeting in Denmark.
    We flown there with electric Phoenix, students from Akaflieg Berlin brougth project B13E and also one Discuss with FES did a nice airshow.
    With fully charged battery I did 10 flights with co-pilots between 80-100 kg weight and in total it was over 2 hours of flight time.
    https://www.dr.dk/tv/se/tv-avisen-m...MC2UL8l0l69XtYLyAHXuUPQNF_guqxWF7Q5-c#!/22:21
    (time from 22:21)
    Nice photos from meeting are also here:
    https://www.facebook.com/Electric-Aviation-Day-110746436948426/
    I hope we will soon start with glider "e-tow" tests to show how universal electric airplanes can be :)
    Have a nice day!
    Martin
    emir_82, henryk and Topaz like this.
  11. Sep 6, 2019 #311
    emir_82
    emir_82
    emir_82
    Jun 25, 2014
    52
    9
    Rosario
    Martin,
    What is the battery capacity of the phi-nix and what gliders you expect to tow?
    I am trying to get argentinian administration to add "electric motor" to the LSA rules for letting the electrics tow and give flying lessons.
    Regards
  12. Sep 7, 2019 #312
    John.Roo
    John.Roo
    John.Roo
    Oct 8, 2013
    266
    183
    Hello dear friend!
    We have 35 kWh battery capacity.
    Motor is designed for max. power 80 kW (107 hp) but actually we are flying in "motorglider mode" so max. power is electronically reduced to 60 kW (80 hp).
    With Rotax version of Phoenix (74 kW / 100 hp) I normally tow all types of gliders from light one seaters up to two seaters like Duo Discus, Blanik, K7, Bocian etc.
    L-13
    LS-8 with water
    One seater Crystal (my first aerotow in France) :)
    It means that with 60 kW I will try to tow one-seaters without water and light two seaters and with 80 kW I will try one seaters with water and two seaters.
    Problem I can actually see is not power of electric propulsion. Problem is cooling. I know is sounds strange :) Especially when efficiency of eletric motors is over 90%. But even 10% of heat is 6 kW (with max. power will be 8 kW of heat) you have to remove from relativelly small area of electric motor. Imagine 17 kg "small metal cylinder" heated with 6-8 kW. The only way is probably liquid cooling. Actually we use air and liquid cooling and next step will be improved liquid cooling. Goal is 50 kw of continuous power.
    We go forward slowly and step by step. From first electric flight in 2011 is a long journey.... But I still beleive that makes sense :)
    Best regards!
    Martin
  13. Sep 7, 2019 #313
    emir_82
    emir_82
    emir_82
    Jun 25, 2014
    52
    9
    Rosario
    Martin,
    Towing cycles are short.
    With a 5 minute towing, 8kW and 17kg of motor you may have not enough time to heat the motor mass having mixed cooling.
    Consider also to add an air vent to the motor with a door. You only need to open it when towing. So you don't add cooling drag when touring.
    8kW isn't terrible. Think in those electric fan heaters, they had 2kw and a poor fan to remove the heat from the electric resistance.
    Regards
  14. Sep 8, 2019 #314
    John.Roo
    John.Roo
    John.Roo
    Oct 8, 2013
    266
    183
    Dear friend beleive me that improved cooling is in this case really important. I am towing to different altitudes and I tow different gliders and to have electric tow plane for "real life operations" needs good cooling :)
    Don´t forget that with increasing teprerature is motor efficiency decreasing. Also... 6-8 kW of heat is generated inside. Positive is that we have solution already :)
    However you are right that for tow tests we really can use already existing version. Only tow altitude will be limited. Following week we will install TOST tow hook and... than I report results :)
    emir_82 likes this.
  15. Sep 8, 2019 #315
    emir_82
    emir_82
    emir_82
    Jun 25, 2014
    52
    9
    Rosario
    Yes, you are absolutely right.
    You have to think in all the weather conditions.
    Another thing that came to my mind is that the best efficiency rpm is not always the working rpm. So, indeed you have to increase cooling.
    Luckily you are putting the battery at only 2C discharge. If you are using the vtc6 or the 25r you have plenty of room there.
    Good luck with the test!
  16. Sep 8, 2019 #316
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,850
    480
    krakow,poland
    =the greatest "+" =LOW NOISE !
    emir_82 likes this.
  17. Sep 18, 2019 #317
    John.Roo
    John.Roo
    John.Roo
    Oct 8, 2013
    266
    183
    Smartflyer Challenge / e-Trophy (14.-15.9.2019)
    https://www.smartflyer-challenge.ch/smartflyer-challenge-etrophy/
    1st place U-15E Phoenix :)
    2nd place Pipistrel Alpha Electro
    3rd place Antares 20E
    Winners flight - Bad Ragaz to Grenchen.
    Direct distance - 158 km.
    Really flown distance (ICG log) - 199 km.
    Flight duration 1h 40 min.
    After landing and taxiing to parking position we still had 28% reserve of battery capacity.
  18. Sep 18, 2019 #318
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,850
    480
    krakow,poland
    =my HERO !!!
    best congratulations !
    -when next E-Phinix ?
    emir_82 likes this.
  19. Sep 20, 2019 #319
    John.Roo
    John.Roo
    John.Roo
    Oct 8, 2013
    266
    183
    Thank you!
    Next electric Phoenix? Hopefully soon :)
    henryk likes this.
  20. Sep 20, 2019 #320
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,850
    480
    krakow,poland
