Sraight'nlevel
- Joined
- Nov 4, 2021
- Messages
- 290
Glide ratio?
Or is it just a box you check off on a form?
page 2 for "box";
Some information about pilot training for motorgliders;
Is 20:1 ok ?
For a soarer ?
Glide ratio?
page 2 for "box";
SGS 1-26 is beautifull "oldtimer" gliderWhen do we talk about soaring....and when just a motorplane ?
Is it the span ?
Schweizer SGS 1-26 - Wikipedia
en.wikipedia.org
Is 12,2 meters still a soarer and what about under 10 meter spanning plane?
It is not only about the wing span, however wing span and wing aspect ratio shows a lot.When do we talk about soaring....and when just a motorplane ?
Is it the span ?
combination of L/D, min, sink ratio and weight
I would personally look for combination of L/D, min, sink ratio and weight (EW and MTOM)![]()
Honestly.... no. At least not for me - I don´t know exact FAA (CAA) TMG definition.Do you think a 9,4 m spanning 2 seat plane could still be a motor glider ?
In the US, I think Advisory Circular (AC) 21.17-2a covers this. Less than 0.62 lbs/ft2 span loading (Gross Weight / Span^2) and 850kg (1874 lbs) maximum weight.Do you think a 9,4 m spanning 2 seat plane could still be a motor glider ?
I'm guessing that a 2 place, 9.4 m span would have a gross weight of about 500 kg. 9.4 m span would meet the requirement for a GW of 268 kg.
Correct, according to the AC, but they might accept something else if you "check the box".Thank you....so wing loading is not a consideration at all.
Maybe, but not sure about that. See this:Wrong. (AC) 21.17 pertains to Type Certificated Gliders and is not pertinent to Experimental Amateur Built.
https://www.faa.gov/regulations_pol....cfm/go/document.information/documentID/22059
EAA Clarifies Motorglider Certification Issue
