Discussion in 'Workshop Tips and Secrets / Tools' started by cdlwingnut, Sep 17, 2017.
  1. Oct 8, 2017 #141
    7,353
    2,120
    Another 3 hours gone. Found some missing $ operators in my spreadsheet, which then revealed a discontinous integral. I've made progress on mitigating that. I just doubled the table size to hopefully get it usable, and broke it again. Reality bckons, maybe I crack this nut tonight?
  2. Oct 8, 2017 #142
    skier
    skier
    skier
    Mar 5, 2008
    1,078
    338
    CT
    Not an update from just today, but rather the full weekend. I pulled the first few rivets in the tail of the CH-601 rudder kit. I also got to see and ride in a CH-750. After seeing one in person and talking with a few forum members, I'm still thinking it seems like a good choice for me.
    FritzW likes this.
  3. Oct 8, 2017 #143
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,752
    3,362
    Las Cruces, NM
    Are the rudders interchangeable?
  4. Oct 8, 2017 #144
    skier
    skier
    skier
    Mar 5, 2008
    1,078
    338
    CT
    No, but I had the -601 rudder kit hanging around. I figured it's a good way to learn on something that doesn't matter at all. And since It's already paid for, it doesn't cost me anything.
  5. Oct 8, 2017 #145
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,752
    3,362
    Las Cruces, NM
    ...oh well. At least when you get the 750 rudder you'll be an old hand at Zenith rudders ;)
  6. Oct 8, 2017 #146
    Mcmark
    Mcmark
    Mcmark
    Sep 24, 2013
    292
    148
    Owings, MD
    Mowed 10 acres of runway for Dad this morning. Then cleaned and gapped the plugs. Figured out that I didn't check the ring gear when I installed the prop. So, off it comes to clock it. Got most of the wing bolts and nuts installed. Hope to run it tomorrow, Kenneth said it was fat/rich at idle, screwed mixture screw in a turn. Will see if that helps. Still got a big list to chew on.
  7. Oct 9, 2017 #147
    Super Moderator Staff Member
    Oct 19, 2003
    6,174
    3,484
    I have been getting absolutely nothing worked on.
    Last Tuesday I had a vision problem, dashed to the eye doctor, and Wednesday AM they vacuumed out my eyeball, fixed the holes and tears and detachment of my retina, inflated my eye with gas, stitched the holes they did the work through, and told me I have to keep eyeballs down for a week or more while it heals. Cannot accomplish anything in the shop, not even cleaning.
    You guys keep building stuff, I am living vicariously through all of you. Grin.
  8. Oct 9, 2017 #148
    10,242
    6,965
    Glad that you got to the physician quickly enough to have it repaired.
    wsimpso1 likes this.
  9. Oct 9, 2017 #149
    Oct 19, 2003
    6,174
    3,484
    I did...
  10. Oct 9, 2017 #150
    Oct 19, 2003
    6,174
    3,484
    That is getting serious....
  11. Oct 9, 2017 #151
    gtae07
    gtae07
    gtae07
    Dec 13, 2012
    1,857
    1,122
    Georgia
    Well, it was yesterday, but I finished sealing and clecoing my lower front skin in place... I wanted sealant there partly to seal out carbon monoxide, but also to help keep belly oil from migrating its way through the skin joint to the inside of the airplane. We've seen that on my dad's -6.
    Eventually the firewall will be getting a full seal of fire sealant as well, but I can't really put that in place till the cowling hinges are drilled and my insulation (engine side) is installed.
    I've been trying to finish the welding project I started months ago (a table for my wife) so I can get it out of the shop and free up some room. Been hitting it with a flap disc to clean up the mill scale, and only have one more part to weld on. Then I just have to fit and stain the wood top.
  12. Oct 9, 2017 #152
    7,353
    2,120
    Ouch. Sounds like a good opportunity to catch up on some reading.
  13. Oct 9, 2017 #153
    gtae07
    gtae07
    gtae07
    Dec 13, 2012
    1,857
    1,122
    Georgia
    :shock:
    What on earth did you do to cause all that? Or did it just happen?
    Though good job getting it fixed quickly and not just waiting around...
  14. Oct 9, 2017 #154
    Oct 19, 2003
    6,174
    3,484
    Done a bunch of that, then spotted five plastic airplane models that have been sitting for 17 years. Just got paint and glue and stuff. I can do this eyeballs down.
    Topaz likes this.
  15. Oct 9, 2017 #155
    Oct 19, 2003
    6,174
    3,484
    Picked the wrong parents and then acquired age. Strongly nearsighted, which means elongated eyeballs, which stretches the forward part of the retina, which it resists, and causes lattice in the retina, which all increase the likelhood of tears and the retina slipping free of the tissue underneath. Then I had a posterior vitreous detachment, where the vitreous seperates from the retina, which happens to folks in their 50's, 60's, and 70's, and can cause tears and detachment of the retina. Two weeks after the PVD, the retina gave up, four holes, two tears, and slipped free of the tissue underneath.
    The surgeon fixed all of the tears, lasered the lattice so it won't cause problems later, and lasered the edge of the retina to make it stay attached. We are waiting for the scarring to finish sealing things up. Given my history, he wants us to go for lasering the lattice in the other eye pre-emptively. It is common in Europe to just do that and not wait for detachment...
    So, be careful picking your parents, and then don't get old...
  16. Oct 10, 2017 #156
    4,061
    1,189
    welded a friends Pitts tail reinforcing bushings for the tail strut reinforcements. Discovered I am pretty good when I have the right size orifice. Made calls to Powder Coaters, only one called back, $125 minimum, for my seat back, probably will not be going that way if they are all about the same. Made 3 calls to Epoxy Primer venders, and found out that all should not be effected by MEK. Decided to do some tests of my heat cured epoxy to see if what I have is effected after a heat cure. Somewhat frustrating not past this bottleneck. https://www.homebuiltairplanes.com/forums/showthread.php?t=28545&page=3&p=405712#post405712
  17. Oct 10, 2017 #157
    skier
    skier
    skier
    Mar 5, 2008
    1,078
    338
    CT
    I was pulling some rivets with my hand riveter when it decided to crap out. I guess I need a new riveter. Any suggestions other than a pneumatic one?
  18. Oct 10, 2017 #158
    Toobuilder
    Toobuilder
    Toobuilder
    Jan 20, 2010
    4,568
    3,409
    Mojave, Ca
    I'm stuck. Lots to do but I can't find the magic solution to several big tasks. Usually, I just downshift into the next thing and hope the solution to the earlier problem will come to me eventually. Now I've kicked enough of them down the road that I have "builders block"... Can't even force myself to do the piddly stuff.
    Now I'm cleaning the shop until this funk passes.
  19. Oct 10, 2017 #159
    TerryM76
    TerryM76
    TerryM76
    Sep 8, 2012
    540
    200
    Tempe, AZ
    Moved the Pober into a bigger T-hangar today. At the end of the day I started test fitting my new instrument panel that I cut out and primed over the weekend. Have some trimming to do before it fits correctly.
    The weather is finally getting comfortable enough to work in the hangar again.
  20. Oct 10, 2017 #160
    12,075
    3,482
    Billski get better.
    The building funk is the hardest thing. A friend who does homebuilt projects with little funk showing, will go stick one bolt in, rivet one rivet, or glue one gusset on. Somehow the next time he shows up he will have a goal for that day. Not that he does not have setbacks, they tend to energize him to get back where he thought was.
