PTAirco
Sep 20, 2003
3,519
Corona CA
I'm actually working on my own stuff for a change. 1942 Aeronca L3B. Second wing is in the silver stage, should be done next week. Then reassemble the engine and bolt the whole thing together and fly it. First time since 1952.
gtae07
Dec 13, 2012
1,932
Savannah, Georgia
Nothing, thanks to Dorian (we left town and visited family, mainly because the thought of being cooped up in a house with a hyperactive 3 year old was much scarier than the storm).
But I got in about an hour of flying this morning and greased both of the landings, then made some suggestions to Dad on ways to deal with his high #3 CHT.
Bill-Higdon
Feb 6, 2011
567
Salem, Oregon, USA
One landed at 7S5 last spring other than gloss instead of drab finish looked very close to original military. He was looking for the original type of radio transmitter & receiver to go in it
gtae07
Dec 13, 2012
1,932
Savannah, Georgia
Painted the accessory case, vacuum pump drive housing, and governor housing. Ran the first set of wiring conduit in the fuselage, and looked at some options for routing other wires and the smoke system line. Gotta order some fittings and such. I'll finish engine inventory soon, and once I work up the guts to write the check I'll order the engine parts.
Toobuilder
Jan 19, 2010
4,666
Mojave, Ca
Did taxi tests and engine performance evaluations on the jet. It's working great. All the engine perameters are within spec (no shock - it's a turbine).
Did some mild aborted TO to about 30 knots. Fun! Lot of push with that little engine when the jet is light.
bifft
Apr 17, 2011
262
Utah
Flew with the wheel pants and gear fairings on. No intersection fairings yet. Gave me another 20mph on the top end, and the extra air fixed by CHT problem, at least in cruise. Top speed is now limited by engine RPM instead of CHT. Around 150KIAS have to throttle back to keep RPM under 2700. Top out 160 or so. Prop (Catto three blade) is labeled 3000, but I'm not racing or anything so try to be nice to my engine.
However it turned my nice ball in the center plane into one that needs a bit of right rudder in cruise. Guess I didn't do as good a job as I thought on alignment. Second flight with just the gear fairings and no pants still had the problem, so it looks like wheel pants are Ok. Will need to adjust fairings.
Also at long last cleared for aerobatics in my plane, so got some of this from my video camera:
gtae07
Dec 13, 2012
1,932
Savannah, Georgia
Minimal progress, just some thinking. Mostly been updating my resume. All purchases are on hold until I know whether I still have a job at the end of October. It's unlikely that I'll be affected but it would be foolish to drop money on airplane parts right now.
7,376
A quick flight to Australia?
gtae07
Dec 13, 2012
1,932
Savannah, Georgia
Lately I've had more time available to work in the shop, which is nice. Fabbed up and painted center covers for the fuel pump, lines, and electrical runs. Was dreading this for a long time but it turned out surprisingly well and I actually enjoyed it.
For now, I'll continue with more systems runs and computer work (wiring diagrams and preliminary panel layout) while awaiting the passage of the layoff reaper. It's been hinted that I need not worry, but I'm sort of wondering if I should paint the edges of my cube with some lamb's blood or something just in case...
Mcmark
Sep 24, 2013
326
Owings, MD
So, when you have something to fly the other projects tend to slow somewhat:(. However, flying is what this is supposed to be about.
I found after re-installing the engine mount on the Tailwind, my math was faulty! Wings were not at all level, so I unbolted gear leg and adjusted the airframe to the correct attitude and proceeded to drill a new hole for the gear leg. After careful alignment and tightening up the leg clamp,I proceeded to drill the new hole. First side went reasonably well. The backside not so much. bought home 4 boxes of drillbits to sharpen. Yay!
I decided to reuse the original cowl but was concerned the inlets were to small to be effective and started doing research. The cowl weighs a ton and I decided to rework the inlets to be more presentable. I am adding the "ramps" to the upper cowl. Any other best practices to consider?
The oil cooler is on the front baffle and not well supported. I am thinking of relocating, and looking for input. Would get rid of a lot of weight out front.
N804RV
Jun 9, 2013
193
Mount Vernon, WA
So, when you have something to fly the other projects tend to slow somewhat:(....
Oh? ....Do tell!
After finally finishing the engine R&R to replace worn/damaged magneto drive gear and spacer on the Sonerai, I finally got back in the air last week. Today, was the first day in a month I actually went to the shop to do a little D-S-P on RV-8 fuselage aft bulkheads. Yay, I've got parts to rivet!
Mcmark
Sep 24, 2013
326
Owings, MD
The Cuby in my avatar. Finally got it flying this summer after several years of repairs and rigging a “flying” airplane. Sure it did....
Spent last evening cutting away the existing inlets on the bottom cowl and removed excess resin everywhere. Some people should not be allowed to use glass and resin. What a mess. Have more to remove.
Will start putting it back together early next week.
Made the decision to move oil cooler to rear baffle. Will have to get engine hung, maybe Monday.
12,571
Thought I was ready for my first engine run. Just a start to check leaks and oil pressure; no cowl. I put a gallon of fuel in the tank. I did not want a bunch in there sitting. Start to push out and I see a puddle. Hmmm. Fuel line from fuel shutoff to gascolator leaking. Drain fuel. Remove line and it disintegrates coming out. Yea. I replaced the ones in the engine compartment; did not think of this one being a problem. Wrong.
cheapracer
Sep 8, 2013
5,990
Australian
I designed a whole new tail, now waiting for my sheets of 6061 to arrive so I can start building it.
So starting to take individual CAD 3D panels, flatening them out, and exporting them to .DXF 2D files so the cnc laser can cut them out, and then ready for folding where appropriate.
4,422
in order for this to work...and I seem to remember your other posts it's working....it need Precision CNC mill,punch,laser,or water-jet to cut/drill,...precision bending ( Amada for example)
cheapracer
Sep 8, 2013
5,990
Australian
Normal press brake (why they don't call them a bender or folder ....)
The cnc laser cut sheet have nipples on them to show where the sheet is positioned in the brake.
