Toobuilder
Jan 19, 2010
5,247
Mojave, Ca
I replaced 4 steel 1/2 inch NPT plugs on my oil sump with aluminum versions procured from the aviation section of Summit Racing. Cost about $3 bucks, took about 3 minutes and saved about 3 oz.
Jul 29, 2005
14,751
Finally decided on a tail surfaces airfoil. Enhanced my weight-and-balance spreadsheet to start tracking costs of individual components.
mcrae0104
Oct 27, 2009
4,034
KBJC
I am relieved to see that I am not the only one who feels like he did something without "doing" something! And thanks for the clever spreadsheet idea. I bet if you divide the total cost by the sum of the moments, your checkbook might balance.
choppergirl
Banned
Jan 30, 2015
1,682
air-war.org
David offered me his Poorboy project today, all I have to do is pick it up, rebuild my ULII-02, and add it and a 30x50 prop and gas tank, so of course the first thing I had to do today is create a paint scheme for it... inspired by the Jet Quickie and well, Udet... though with Pepe onboard, maybe I should run with some French Colors instead... ou? Qu'est-ce que tu penses?
I get to be a bona fide Test Pilot now.
Choppergirl's Lost Girls Flying Circus Black Sheep Airplane Projects +1 :) Maybe. Also Mac is mailing me an Airmap 2000 today. Aviation GPS +1 :)
Don't count your airplanes/gps's before they hatch... tho. Still, I can't resist the pull of pixel painting visualization...
Otherwise, I mowed more briars yesterday around my future barn hanger... need more sheltered space quick!
Free Little Craigslist Riding Lawn Mower set to "decimate"... turn-right-area-for-truck after-pulling-plane-trailer-through... "clearing work" continues:
The first batch of pulling oodles of nails out of scavenged house trailer lumber... in this case, 2x4's, which will be used to build swing open on heavy duty hinges barn door frames:
I sniped a Casio PAW-1500 altitude/barometer/compass watch off eBay for $26 (that took a really long time... two months of watching lots of abc watches), and this t-shirt to match my plane theme for $11:
The T-shirt is real :) We're all mad here.
My dad say's he's going to borrow it if he ever has to go to court, a job interview, or psychiatric evaluation.
Direct C51
Aug 26, 2014
142
Bakersfield, CA
↑ So nothing again, like usual. Maybe I need to change my name to "Direct C51 Girl" and I'll get free stuff too. Nah, I'll work hard for what I have.
Today I removed the cowl and inspection panels so that the DAR can look at my Sonex tomorrow. I also cleaned my airplane and my hangar to look good for the DAR. Tried to fly for my tailwheel endorsement today as well, but the rental airplane wasn't ready. I guess my first flight will have to wait.
stuart fields
May 30, 2008
295
Inyokern California
I hope you applied anti-seize if the sump is also aluminum... Was this a solution to a leak issue?
Toobuilder
Jan 19, 2010
5,247
Mojave, Ca
Yes, standard aviation maintenance practices applied. The sump does not leak because the engine has not been run yet (no oil in sump). The plugs were replaced strictly out of weight concerns. No need to carry around extra ounces when it can be easily rectified by throwing a few pennies at it.
stuart fields
May 30, 2008
295
Inyokern California
Toolbuilder: You are a neighbor. I'm presently building an oil sump to provide lube for the sprag clutch on my Allison powered Rotorway look-a-like. Upside down mounted engine created the need for different oil system for sprag. I've been stuck with steel fittings to get non-pipe thread for cast aluminum housing. Past history of aluminum and SS. on a 36' catamaran has created a lot of caution with dis similar metals.
jsoar
Mar 17, 2009
25
Central IL
A few days ago I made the first and second flights of my old Blue Tail Hawk with the new Polini Thor 200. They went well, the engine had plenty of power and ran real smooth. But it was running a little rich with no air filter so I need to do some rejetting.
I also have been doing the surface finishing work on the new wings for my Red Tail Hawk. I fitted them to the existing RTH air frame earlier this summer, and got the flap and aileron linkage worked out too.
Today more finish work. I applied the second coat of epoxy/micro to fill the weave on the left wing bottom surface. Next have to do a little more spar cap filling. Still have the top surface and nose to do, and then the second wing, hopefully before it gets too cold to heat the shop enough for epoxy work. Then I plan to block sand a spray-on high build primer, like Smooth Prime UV, to get the final laminar surface contour. I can do that in a cooler shop this winter.
stuart fields
May 30, 2008
295
Inyokern California
Practiced aluminum welding on some 0.032 5003. Great learning lesson: I need more practice!!! I carefully set up my Miller Dynasty 200, got the 1/16 2% special electrode,1/16 filler rod got a lens cup installed SS brushed the aluminum, wiped it down with acetone, wiped the filler rod with acetone,,,, Then had trouble with the foot switch and the auto darkening helmet. It was a good thing I was practicing. I ended up with SCRAP without the S.
ScaleBirdsScott
Feb 10, 2015
1,331
Uncasville, CT
Pinned the rudder pedals to the hangers and started the process of mounting the brake master cylinders. Needed to make an extension below each cylinder to adapt it to fit the pedal, so got some milling time in to modify some tube.
Going to get some lathe time in because we have male universal joints and male threads on the end of the cylinders, and they aren't even the same thread. Instead of ordering new joints I'll just make a female-female adapter.
I'll try and get some pics of the assembly next time I'm in there.
ScaleBirdsScott
Feb 10, 2015
1,331
Uncasville, CT
Imagine how awesome this thread would be if people posted photos once in a while.
See I tend to take all my pictures on my actual camera, and I only tend to transfer pics off it every few weeks once the card fills up. And in 2-3 weeks what I did yesterday isn't so relevant. I suspect that's half the battle.
I have to remember to bring my phone into the shop and take pictures cuz those are instantly ready to send.
8,812
I've been clearing up and packing stuff to move to the Smokys. I did my GY6 bits last night. While they were in my hands, I measured and weighed the crank, flywheel and cam chain so I can calculate their rotational inertia for TV analysis.
