pylon500
Dec 26, 2003
520
Taree Airport Australia
While making new exhaust pipes for a 912 install a few weeks back, I needed the 'ball tubes' that go into the Rotax muffler, until I found out they're around $35~40 EACH, here in Oz. So with a bit of machining and some bits of stainless tube, I swaged up some ends for myself;
Basically pressed a larger flange, then set up in lathe with a roller and swaged back to shape.
Having done this, I later realised I needed all those little bent hooks for the exhaust springs (well, eight anyway).
Didn't even bother to find out what they're worth here in Oz, to say nothing of postage and waiting during the Christmas rush, so;
Down to 'Bunnings Aerospace' (this is an Aussie in joke, it's a common hardware chain), for some stainless nails;
Bandsaw a couple of lumps of alloy offcut, and to the press...
How does it go, 'Necessity is the mother of invention'?
dwalker
Mar 6, 2021
705
Tennessee
I've been getting the bits together to pull the plane off it's gear and on its side so I can sand, fill, prime, and paint the underside of the fuselage after building the speedbrake. Last week I got the final bits needed for the vacuum bagging setup. I decided not to risk the old, well traveled Horror/Fright vacuum pump failing mid-layup, so I went down and bought a new Horror/Fright pump. Aircraft Spuce sent me some fresh consumables and Fibreglast sent some odd bits.
I have also been setting up a 3D printer, and today have it making an enclosure for the Arduino and its ancillary components.
A little bit, every day...View attachment 20211221_134823.mp4
Doran Jaffas
Jun 25, 2019
622
The number 1 cylinder on the Continental 0-200 in 625MS has been overhauled and reinstalled due to exhaust valve leakage. All cylinders now are at 70 or higher. I am curious, how much horsepower is considered to be lost with one cylinder on the 0-200 that has basically dropped to zero? I know the hp loss on the VW 2180 but I haven't been able to even get a ball park estimate on the 0-200 though stating the obvious, I haven't called Teledyne Continental....yet.
Thanks,
Doran Jaffas
PS. The next plan will be to remove the wings and prep my beloved Tailwind for a complete repaint in the near future.
Toobuilder
Jan 19, 2010
5,643
Mojave, Ca
Did this first actual weigh of the Rocket since the major rework. Way back in 2013 it was a standard Bendix FI/Slick mageneto, simple VFR ship. It weighed 1251 pounds back then.
Since then I added dual batteries, dual alternators, a full return duplex fuel system, SDS EFI, full cooling plenum, big full filter airbox, augmentor tubes and lower cowl, giant oil cooler and plenum, an extensively reworked cowl (full of filler) and a new panel with dual EFIS displays. New weight today on the same scales showed 1243 pounds for a net loss of 8 pounds.
The loss of weight was not as hard as it sounds - the original builder did NOT "think light". All the wiring in the airplane was 14 AWG, for example. There were countless examples of builder details that were simply much heavier than required to do the job, and almost every system I touched went back as light as I could make it. I knew the dual battery scheme required by the EFI was going to cost me some weight so I tried to make up for it everywhere else. I would have considered it a victory to break even - but a net loss is awesome.
dwalker
Mar 6, 2021
705
Tennessee
Today was the first step in repairing the above mentioned issues. 2 layers of BID over the entire span, one layer of carbon fiber over the repaired area, and one layer of carbon from one side to the other.
Pics are of the last layer of carbon with peel ply.
Used about 3oz of MGS 285 with 287 hardener for the layup, and a little bit for the micro used on the foam.
Next up is figuring out what to do about the hatch while I build the forward bulkhead and instrument tray.
Toobuilder
Jan 19, 2010
5,643
Mojave, Ca
Worked on a ground adjustable, fixed blockoff plate for the oil cooler on the Rocket. Test flew it and its almost warm enough in cruise now. On the way back from the flight I managed to fly directly over Statolaunch as it was on initial to 30 at MHV. Big beast.
Also worked on the jet; Closed out my air compressor and wiring and installed the nose cone. One compartment down, a few more to go.
bhooper360
Dec 9, 2021
132
Today and yesterday, I assembled my CNC foam cutter... virtually.
A quick nap, some more overengineering, and submit an order for all this **** from McMaster. I'm super excited.
dwalker
Mar 6, 2021
705
Tennessee
I like it! Are you working off of a set of plans or just having at it?
How large a span are you attempting to cut, and have you devised a way to adjust tension as the wire heats up?
gtae07
Dec 13, 2012
2,322
Savannah, Georgia
Finished and installed the radio/intercom harness. Left a couple spare connections for a music plug etc. coiled up.
Finally crawled underneath and grounded my fuel pumps and finished securing those wires.
Got the cabin heat control cable almost fully installed and realized I now can't find the all-metal locknut that secures the end of the cable. It's floating around the shop somewhere and it was my last one. Once I find that and get it installed (or get a new shipment of them), I move on:
Brake cylinder return springs
Terminate and connect SDS mixture knob
Terminate the smoke arm switch
Install pitch AP servo and ADS-B receiver
Install red belly beacon
bhooper360
Dec 9, 2021
132
I like it!
Thank you!
Yes.
The width of the baseboard is about three feet. The cutting length varies.
My sister isn't happy about her guitar's tuners missing. Well, engineering is all about making worthwhile compromises.
