What could be done to reinvent the Affordaplane to a more homogeneous project?
kennyrayandersen
Jun 6, 2011
73
Ft. Worth TX
this is a layout of a more homogenous frame, in my eyes.
I'm still looking for a landing gear arrangement, but the strongpoint at the upper corner of the firewall to attach de suspension pleases me.
This is just a mock-up, its not the airframe which is going to fly.
So I assume what you mean is you aren't going to attach the landing gear where you got them now right?
Otherwise you taken a half-bad design and made it 100% bad. The beef i have with the original is that there is no good load path for the landing gear into the fuselage - especially if an instruction is hit the at landing gear member drives a vending load into the lower frame member. That picture provides no good load path. If you care about that sort of thing. I would recommend a triangle. One should be at the front firewall and the aft should be at the vertical member just aft of the pilot.
erkki67
Feb 18, 2010
2,436
more like this one?!
blane.c
Jun 27, 2015
4,587
capital district NY
Whenever I look at something like this I can't help but think the first rudder input of significance will wrap the fuselage about the yaw axis.
Aerowerx
Dec 1, 2011
5,727
Marion, Ohio
Did you consider....
Although it is hard to see in all pictures, there are cables running from the rear fuselage to the wings. These oppose the fuselage bending forces.
Speedboat100
Banned
Nov 8, 2018
1,900
Europe
No, I gave just the inputs. The initial frame came from FritzW and the fine tuning came from a friend of mine, I think he is occasionally reading here too, DanielV
What is the glide ratio and total drag in sqfts ( flat plate ) ?
