wanted provision 8 lower case with gearbox for ROTAX 377
Discussion in 'For Sale / Wanted' started by Tuneturkey, Jul 5, 2019.
  1. Jul 5, 2019 #1
    Tuneturkey
    Tuneturkey
    Tuneturkey
    Dec 29, 2018
    46
    12
    baton Rouge, LA 70816
    I have a working ROTAX 377 with drive shaft designed for strait drive shaft to remote belt drive PRU i.e. powering a Quicksilver UL. Would like to convert to gearbox - PRU for direct connect to prop. I understand that the 377 is physically same as the 477 so would consider similar unit from a 477. Intent is to move all other parts over to the new case. Any comments on the intended process are welcome!
    Thanks
    Tuneturkey
  2. Jul 10, 2019 at 5:27 AM #2
    Armilite
    Armilite
    Armilite
    Sep 6, 2011
    2,934
    228
    AMES, IA USA
    I doubt that will work. Early 377's used Smaller Crank Bearings, not exactly sure what year they changed over, I can tell you 1993 was the first year for Provision 8 Cases. The 377/380 is the same basic Engine. Is your 377 a Provision 4 Case or Non-Provision Case? If you want Pro8, it would be simpler to sell yours and just buy a complete 1993+ 380. Rotax Rick did have some Pro8 447UL Cases. You can buy Heads & Cylinders and Cranks off eBay.
  3. Jul 10, 2019 at 5:39 AM #3
    MadProfessor8138
    MadProfessor8138
    MadProfessor8138
    Nov 4, 2015
    414
    174
    Ekron,Kentucky
    Wasn't one of the b-box's a provision 4 ?
    Kevin
  4. Jul 10, 2019 at 5:51 AM #4
    Armilite
    Armilite
    Armilite
    Sep 6, 2011
    2,934
    228
    AMES, IA USA
    A & B Gear Box Internally is basically the same. The Pro4 Case with the A Box needs an Adapter Plate. Never tried a B Box on a Pro4 Case. The B Box bolts onto a 277. There is a Long and Short PTO Gear for the B Box depending if mounting it Up or Down.
  5. Jul 11, 2019 at 12:01 AM #5
    n3puppy
    n3puppy
    n3puppy
    Jun 25, 2019
    3
    There was also an adapter plate for early 3 bolt crankcases (pre-Pro4)
    Not sure if that is what Armilite is calling a Non-provision case.
    Finding a 3 bolt adapter is probably a long shot.
  6. Jul 12, 2019 at 4:48 AM #6
    Armilite
    Armilite
    Armilite
    Sep 6, 2011
    2,934
    228
    AMES, IA USA
    You have Non Provision (No Bolt Holes).
    Provision 3
    Provision 4
    Provision 8
