Wanted :186 cu in, Radial Y ; (30 hp) @ 1,300 rpm -- !
3,042
How 'bout a 5 or 7 cylinder radial using O-200 cylinders? Paging Pete Plumb... :)
An R-250 or R-350 sounds cool! You’d likely have to turn the cylinders 90° to the airflow from how Continental did it but come to think of it that may be the way air is supposed to pass over the fins anyways.
Bille Floyd
Sep 26, 2019
165
The VM R5-420 radial , is 420cc , but only puts out 25 hp ; i
would have thought it could have put out more hp ?
Bille
crusty old aviator
Feb 17, 2014
114
Grantham, NH
Building one requires a LOT of machining. If someone is VERY serious about building one, I have Jack’s email address that I can PM, but he’s too busy to interact with the merely curious and tire kickers. He sells plans only now...though I’m not sure if he’s still doing that. They were around $200. If you want to use cylinders other than VW, I advise you to study up on radial engine design & theory and design & build one using those cylinders instead of trying to adapt Jack’s designs. I, too, pondered designing & building a 75hp 3-cylinder radial, using 0-200 pistons & cylinders, as a substitute for a Lawrance L-3, but life kept getting in the way and I moved on.
crusty old aviator
Feb 17, 2014
114
Grantham, NH
At 4500 rpm? It would need a PSRU, which would dramatically increase your torque, unless you’re putting it on something really tiny, like a later Davis single place.
addicted2climbing
Jan 27, 2012
997
Glendale, CA
Hello Crusty,
If you have Jacks email, I would like to contact him for plans if he is still selling them. I just bought a Tormach 1100 and it would be a fun project. If needed have access to a larger mill for larger parts. Feel free to PM me his email if you don't want to post it publicly.
Thank you,
Marc
