LittleBird
Looking for a set of 600X6 tires. I am wanting the rounded look of tire and not the riding lawnmower square look tires. This is one I found that may be correct:
TIRES FOR ULTRALIGHTS from Aircraft Spruce
It is the second one up from the bottom. Does anyone have these tires? Maybe send a photo of the tire mounted so I can see what they look like? Right now I have regular aircraft tires mounted and they are a heavy overkill.....heavy in a bad spot as the tires are ahead of the CG where it is already nose heavy. Every little bit counts ya know. If this isn't right, does anyone know of a very light airplane tire that has a rounded profile that would work for me. Probably needs to be 4 ply minimum.
