vanagon watercooled??
Discussion in 'Volkswagen' started by revkev6, May 11, 2017.
  1. May 11, 2017 #1
    revkev6
    revkev6
    revkev6
    Mar 9, 2010
    425
    91
    massachusetts
    has anyone tried using a vanagon watercooled VW motor in a plane?? similar to an aircooled motor but 95hp stock with water cooling.. it must have been discussed at some point.
  2. May 11, 2017 #2
    6,589
    5,366
    Isn't that what Rotorway did?
  3. May 11, 2017 #3
    12,055
    3,476
    Run away! Those were terrible engines. Concept is fine; never refined to be better than a grenade on wheels. They tend to blow head gaskets and overheat in one of those orders. I don't know if there was a real fix but swap in another. I think Rotorway did their own development.
    rv6ejguy likes this.
  4. May 11, 2017 #4
    Jay Kempf
    Jay Kempf
    Jay Kempf
    Apr 13, 2009
    3,778
    1,034
    Warren, VT USA
    SUBARU!!!!
  5. May 11, 2017 #5
    13,171
    5,083
    I refuse to use a machine with two "U" I. The name. At least that's the excuse I give my wife when she asks me to vacuum the carpets.
    Tiger Tim, don january and cheapracer like this.
  6. May 11, 2017 #6
    revkev6
    revkev6
    revkev6
    Mar 9, 2010
    425
    91
    massachusetts
    except the concept was supposed to be lighter and direct drive.... subaru while making more power is much heavier especially with a redrive...
  7. May 11, 2017 #7
    fly2kads
    fly2kads
    fly2kads
    Jan 2, 2010
    1,497
    554
    Justin, TX
    The usual suspect in the wasserboxer is the water jacket seal at the head, as opposed to the seal at the combustion chamber. It apparently took a while for VW to figure out that corrosion of the aluminum parts was allowing leaks to develop. The fix was a pretty simple switch to phosphate-free coolant mixed with distilled water. Properly maintained, these motors work pretty well. I drove a Vanagon with its original wasserboxer and had good service from it. They do require more attention than a modern motor, but as an enthusiast of old VWs, I'm pretty used to that. ;) All that said, I'd pick a Subaru over the wasserboxer for an aircraft engine.
  8. May 11, 2017 #8
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,831
    4,299
    Australian
    i think The Samba dot com will yeild all the info you want about them.
    https://www.thesamba.com/
    Seems to be a lot of conversions to other engines for those vans, so doesn't look good.
  9. May 11, 2017 #9
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,279
    1,473
    Marion, Ohio
    Would you use it if it was called "Pleiades"?
    Look up the meaning of both.:gig:
  10. May 11, 2017 #10
    rv6ejguy
    rv6ejguy
    rv6ejguy
    Jun 26, 2012
    3,749
    2,825
    Calgary, Alberta, Canada
    Highly doubt it's much lighter than a Subaru of similar power. An EA81 pumps out 100hp with a cam change and the long block weighs under 150 pounds. EJ22 is 188 lbs. 135 hp, EJ25 sohc 194 lbs. 160-170 hp. Hundreds/ thousands used in aircraft, hundreds of thousands of flight hours on them by now. Some very successful DD turbo ones, lots of redrive choices. None for the VW and no track record in flight for them either.
  11. May 11, 2017 #11
    7,349
    2,117
    Just say no!
  12. May 12, 2017 #12
    don january
    don january
    don january
    Feb 11, 2015
    2,723
    1,163
    Midwest
    The EJ25 SOHC SUBARU looks hard to beat, especially being's my wife's car has one under the hood.;) I owned a water cooled Vanagon and in truth it was a dog in a head wind, on the highway that is.
  13. May 12, 2017 #13
    revkev6
    revkev6
    revkev6
    Mar 9, 2010
    425
    91
    massachusetts
  14. May 12, 2017 #14
    fly2kads
    fly2kads
    fly2kads
    Jan 2, 2010
    1,497
    554
    Justin, TX
    And uphill. Don't forget uphill. ;)
