Using truck diesels for Beaver-type large Bush planes. Perfect match?
Discussion in 'General Auto Conversion Discussion' started by Doggzilla, Aug 2, 2019.
  1. Aug 3, 2019 #21
    pfarber
    pfarber
    pfarber
    Feb 21, 2019
    194
    9
    Pennsylvania
    One offs of 20year old installs are not giong to cut it. Yes, the LS1/2/4 is a good solid motor, but not in the power/weight of the 4 place sub 200kts cruiser. I don't see diesels getting the weigh down for a 2-4 place plane.
    Once you get out of the 150-160-200hp range engines are plentiful. But the market really is the 150-200hp range.
    If the FAA would allow a company to license O-360s prints to clone the engine you could put out a to-print-spec engine for less than $10k. You can get a custom one off forged crank for less than $3k. Yet new O-360 cranks are $8k with a $4k core. NO. Its not about low production numbers. Its about holding the market hostage with FAA regulations.
    I wonder if the Magnuson-Moss act would apply to aircraft???
  2. Aug 3, 2019 #22
    11,424
    3,170
    Have to remember weight of fuels. Gasoline, auto or airplane is a little more than 6 lb gallon. Jet is close to 7 lb and diesel is 8.5 lb. you have to put that extra pound of fuel through the propeller power wise to be even. 100 gallons of Jet weights 100 lb more. Can you extract the power so you only have to carry 85 gallons just to be equal gross?
    Wittman had two different Buicks in his plane. One was bigger displacement. One is on a stand in his Oshkosh hangar. The smaller engine is a little bigger than a O200 and the bigger one was smaller than a O290. Smaller prop and willing to spin it fast got the same performance as an airplane engine, 3200 rpm at least. I read he also pulled the power way back when cruising; back to normal airplane rpm speeds of 2200-2500. I’m sure it was some for noise and some for longevity.
  3. Aug 3, 2019 #23
    akwrencher
    akwrencher
    akwrencher
    Oct 16, 2012
    1,080
    377
    Gustavus, AK
    Pretty sure it was a typo, Diesel can't weight 8.5lbs per gallon, it would not float on water.
  4. Aug 3, 2019 #24
    6,414
    1,665
    Jet A and diesel are both close to 7lb/gallon. About 10% more than gasoline.
  5. Aug 3, 2019 #25
    11,424
    3,170
    it Is right... in imperial gallons. Oops
    pictsidhe and akwrencher like this.
  6. Aug 4, 2019 #26
    6,414
    1,665
    Heh, us Brits, Canucks and Aussies are supposed to be the ones making that mistake!
  7. Aug 4, 2019 #27
    6,919
    5,833
    Sweet little engine. I had one in a 1968 VW bug.
  8. Aug 4, 2019 #28
    Hephaestus
    Hephaestus
    Hephaestus
    Jun 25, 2014
    927
    203
    YMM
    Lol, can't the Americans just start saying 3.785 liters instead. Aren't they the last imperial holdouts?
  9. Aug 4, 2019 #29
    PW_Plack
    PW_Plack
    PW_Plack
    May 25, 2015
    144
    66
    West Valley City, UT
    Even if the factories don't turn out car engines which can run at 100%, there are aftermarket solutions. Nelson Racing Engines is building a twin turbo Chevy LS which, at only 260 cubic inches, has been test run at 1200 HP, full boost at 7,000 RPM, continuous for multiple five-minute dyno pulls.
    Here's video of the first flat-out dyno pull.
    The application is large hydroplane racing, where this engine will compete in the same class as 470 cubic-inch normally-aspirated V8's. There is another video discussing the internal mods done to keep the engine together under this severe use.
  10. Aug 4, 2019 #30
    litespeed
    litespeed
    litespeed
    May 21, 2008
    1,390
    246
    Sydney
    Forget the truckdiesels and go a modern turbo diesel form a euro company. They have the power, engineering and low weight.
    If going for Gas? My pick would be a 2 valve BMW V12 M70 at 5 or 5.3 litres. It is light weight, very compact, very simple for a modern engine and has standard completely separate ignition /ecu's per bank. So built in redundancy allowing at least 6 cyclinders if a ecu fails.
    They were designed to move a limo, have heaps of low down torque and incredibly smooth. You can place a coin on its edge whilst running and it does not fall. I have done this. They easily powered a 2.2 ton limo at 170mph with limiter removed. No vanos or other complex stuff to fail. Just simple two valve OHC.
    They are very well suited to aircraft either direct or redrive. The harmonics are very sweet been a silky smooth V12.
    Stock they make 300hp , but were built very conservative for power and can easily make 450 hp atmo and still be happy to do big miles. Naturally they also turbo or supercharge very well. 450hp with a supercharger would be a simple matter.
    With different heads this engine formed the mighty Maclaren F1 engine.
    The engine is very compact as a 60 degree V12 and weighs only 40 odd lbs more than a period BMW 2.5 six. They have alloy blocks. It fits into even a old e30 3 series, any space that can take the six will take the V12, so cowl friendly.
    They have been used successfully with redrives on aircraft.
    The Vickers Vimy replica used them but BMW America sued them to stop it been flown in the USA. Stupid lawyers.
    I would not expect this to be a problem anymore as long out of production.
    Also make awesome boat engines and the hotrodders have finally started using them.
    A friend who builds BMW engines for motorsport has 3 brand new ones in his workshop. Lovely engine.
    I think this would be a lot better than a V8 when redriven due to inherent balance and smooth harmonics of a 60 degree V12.
  11. Aug 4, 2019 #31
    litespeed
    litespeed
    litespeed
    May 21, 2008
    1,390
    246
    Sydney
    Just checked the weight sans accessories- 420lbs.
    So no heavyweight.
  12. Aug 4, 2019 #32
    6,414
    1,665
    5 minute dyno pulls do not come anywhere near aircraft use. You need to test for hours at a time, not minutes.
  13. Aug 4, 2019 #33
    6,414
    1,665
    The BMW V12s do look good. Rolls Royce has used at least one BMW V12, so some nice valve covers may be found!
    The Vimy injunction was overturned a few days later, by the same judge who orderd it. I guess he became a judge after failing to suck enough blood as a lawyer?
    litespeed likes this.
  14. Aug 5, 2019 #34
    PW_Plack
    PW_Plack
    PW_Plack
    May 25, 2015
    144
    66
    My point was five-minute pulls at more than 4HP per cubic inch are an impressive start, and certainly validate the block/head sealing and cooling mods NRE has come up with to keep engines alive. After 12 of these test runs, the bearings looked like new. I have no doubt a larger displacement Chevy LS running 200-300 HP could earn a long TBO in an aircraft with similar prep.
  15. Aug 17, 2019 #35
    Urquiola
    Urquiola
    Urquiola
    Aug 23, 2013
    24
    Madrid, Spain
    Don't forget this article: 'Power Struggle: Why car engines won't fly', Don Sherman. Air&Space, December 1996-January 1997, pgs 71-81. Salut +
  16. Aug 17, 2019 #36
    Turd Ferguson
    Turd Ferguson
    Turd Ferguson
    Mar 14, 2008
    4,661
    1,624
    Upper midwest in a house
    Anybody that has a Beaver or large bush plane is likely trying to make a buck with it and a non-certificated engine will never be part of that equation. Bolt on a PT6 powerplant and its good for 4-5000 hrs of year round reliable service, which is what's needed in the bush.
    akwrencher likes this.
  17. Aug 17, 2019 #37
    Turd Ferguson
    Turd Ferguson
    Turd Ferguson
    Mar 14, 2008
    4,661
    1,624
    The US has just announced they will be converting all measuring units to metric and be 100% within a few yrs. Due to the complexities they will be making the change inch by inch.
    Mad MAC, Jerry Lytle and Sockmonkey like this.
  18. Aug 17, 2019 #38
    Sockmonkey
    Sockmonkey
    Sockmonkey
    Apr 24, 2014
    1,650
    430
    Flint, Mi, USA
    I think you could get more out of a Beaver by putting a lifting tail on it like they did with the Westland Lysander, which is comparable to the Beaver in terms of role and configuration.
    [​IMG]
  19. Aug 17, 2019 #39
    11,424
    3,170
    The metric people must have been the ones who invented the trophy for all participants. Look we all have the same numbers. Same small cars. Same LSA airplanes. Same monetary system. Same. Inches and feet. Not the same. Different cars, airplanes, money. Always options.
  20. Aug 24, 2019 #40
    pfarber
    pfarber
    pfarber
    Feb 21, 2019
    194
    9
    Pennsylvania
    The problem is that airplanes don't need 400hp. Anything over 200hp for most GA would be overkill.
    The sweet spot is the 150-180hp class. Get a motor that can do 180hp for less than 300lbs that burns Mogas and if it costs less than $10k you'd have a winner.
    Auto conversions make the money at the buy. $10k vs $30-45k. $20k over the life of the motor means almost no ROI... its just a money pit.
    I always laugh at certified airplane owners who say they fly for $45/hr. Means NOTHING. At the end of the year you have fixed expenses that don't care how many hours its takes to save.
    Per hour operation can be the same or higher, most will never fly enough to see it mean much.
