Unbiased look at AeroVee 2.1?
Grumpy Cynic
7,492
There's also the Quickie Q-2 with a 64hp revmaster.
And this is classic example of what not to put a VW conversion into. Built light and flown expecting moderate cruise speeds it worked - barely. There is a reason most now have O-200's or Jabiru 3300's.
Re-read post #11. There is simply no substitute for real world experience.
autoreply
Jul 7, 2009
10,762
Rotterdam, Netherlands
You're absolutely right, but the A-40, A-65, and Aeronca E-113 made power at 2500 rpm or less. Not 3,000+. The difference in prop diameter really matters at low speed.
Yep, static thrust (big prop at low revs), much more so then HP are the limiting factor in take-off performance. Expect almost twice the TO roll for 80 hp@3300 rpm vs the Rotax 912ULS (100hp) with both the biggest (climb) prop they can swing.
saini flyer
Mar 12, 2010
478
Dallas, TX
Good solid numbers that shows the practical difference, Thanks.
Now I am curious to know the difference in the climb performance for comparison.... :)
8,801
On my !835 cc VW engine with single port heads and small intake and valves for low rpm torque, I am using a 60" X 26" Culver prop. It will shove you back in the seat as you feed full power and rotate in about 200'-250' and climb 1200-1300 fpm. Stall speed is about 28 knots. ROT climb RPM is 3050 rpm, so I am not getting the full 60 hp with this prop, but with a 80 mph cruise at 2650 rpm, I will keep it. Dan
autoreply
Jul 7, 2009
10,762
For climb, RPM is far less relevant; the difference in prop efficiency there is a wash for most aircraft (unless climb occurs at very low speeds). It's certainly not linear with power though. Very important for draggy aircraft (like the Sonex), where you need a considerable amount of power to just overcome the drag of the airframe.
An RF5B with 20 hp less as a Sonex and 100 lbs heavier will still have the same climb speed.
dino
Sep 18, 2007
688
florida
Climb rate is also highly dependent on span loading.
Dino
glenbradley
Jan 15, 2020
Both of our two place designs use the Revmaster 2300 engine which has several engineering/design changes over other VW engines. It is truly superior and robust. I have almost 900 hours on my CX5 and I still do not have to add oil between oil changes. With a Zenith carb it is good at high altitudes and requires only a 5 min carb setup
Dr. Glen Bradley
Thatcher Aircraft Inc.
CX5 tandem. CX7 SbyS
8,801
If I was going to buy a VW engine, it would be the Revmaster engine. Hummel engines by Scott Castler would be second.
I never liked the slide valve carbs ( been there and done that ) and I do like the Zenith carb, so my Revmaster would also have the Zenith carb. Better carb than the Stromberg carb for the small continental engines. Like you said, easy to set up and trouble free. I never had any need for mixture adjustment going from 500' agl to about 10k and just turned the mixture screw 1/2 turn for summer in May and back again in Oct where I live. Never missed a beat in 10 years.
14,177
I think one of the slight differences is you probably have a Zenith jetted leaner overall over an airplane carb at full rich. Full rich is idiot proof. May I take you by a flight school. A builder has his hand in setting up the carb. It’s closer to best power but just a little richer. It already leaned some by airplane standards so going high is not such a loss.
Derswede
Jan 6, 2016
1,008
Central North Carolina
NC Pilot, there is a VERY nice Sonex at the airport at the Montgomery Co. airport below Asheboro (near Candor/Star, NC). The owner has quite a bit of experience with the Sonex. Not sure what engine is currently installed, but you should be able to get some information from him. Can't remember his name, but he is a regular who hangs out at the airport. Where are you based? (never mind, just saw Salisbury, Used to fly out of "Lake Norman International" my self.)
Derswede
C Michael Hoover
Aug 24, 2019
58
The one guy lived and flew in South Florida. It didn't seem to bother him unless he was loaded down. Didn't stop him, he just backed further up the grass runway they have at his airport. Don't remember how long the strip was, X05 I think. Indian town, florida.
X05 is Pilot Country, NE of Tampa International. No Sonex's here. Indiantown is X58.
8,801
I remember somewhere (might have been on this site) that the design of the Zenith carb is altitude compensating a certain amount in the mixture. Very simple carb to set up, and when set, it tends to stay the same at any altitude.
Daleandee
Sep 11, 2015
1,210
SC
I see that we are replying to a thread that was last visited in 2013. As far as a Sonex and an Aerovee ... I had an Aerovee powered nose dragger Sonex. I now have a 3.0 Corvair powered tail dragger. Needless to say I'm nearly a zealot that insist that the 120HP Corvair is the engine that this air frame needs. Plenty of power, no overheating, great sound, and the most important thing ... it's been extremely reliable.
Dale
N319WF
PS: 1000% agree with Pops ... no slide carbs for me!
Latest posts
