Ultralight markings
8,648
I know that 103 s need no markings at all. But what markings can they have? Should I build a 103 warbird, how many markings can I use without getting into trouble?
Roundels and squadron markings I suspect will be ok. But what about the serial number?
3,381
I would think the only reason you couldn’t put an N number on would be so that the wrong person doesn’t get in trouble when your buzz job gets phoned in.
13,677
Remember one thing, paint is weight. It adds up fast. A full paint job can add 10-30 pounds on a small airframe.
TrikeTrash
Feb 8, 2014
12
Kingston, TN (12TN)
I have 2" tall letters that spells out "ULTRALIGHT" on my main mast (I have a trike), on my instrument pod I have 1" letters spelling out "254 LBS", on my gas tank I have the numeral 5. Heres why - I figure if I crash or land somewhere I shouldn't, the first person on the scene is going to be local law enforcement. They will undoubtedly call the FAA and describe the trike as an ultralight, 254lbs and 5 gallons of gas, plenty of info for the FAA guy to say, "it's not my problem."
An ounce of prevention is worth more than a pound of cure...
9,380
I heard of one guy who put "NATIONAL GEOGRAPHIC" on his plane. He wasn't affiliated with National Geographic, he just figured that most people like NG and if they saw a low flying plane they'd figure it was on a photo mission for a good cause and not freak out and call 911.
jedi
Aug 8, 2009
2,168
No problem. I you register with an UL organization they will assign an Ultralight identification number.
TrikeTrash said "I figure if I crash or land somewhere" I think the correct wording would be "when" not "if".
blane.c
Jun 27, 2015
3,956
capital district NY
Cold.
FritzW
Jan 30, 2011
3,896
Las Cruces, NM
If you can paint an N number on your car or your bass boat, you can paint it on an ultralight. ...but you'd be asking for a whole lot of unwanted attention.
8,648
That is what i thought. But most, if not all, historical Hurricane serials didn't star with an N
FritzW
Jan 30, 2011
3,896
Las Cruces, NM
After a quick look through AC 103-7:
Unless your part 103 ultralight vehicle is going to be "certificated and operated as an aircraft" or be "used exclusively in the service of a Federal, state, or local government without an airworthiness certificate." you don't have ANY marking requirements or restrictions.
Aerowerx
Dec 1, 2011
5,610
Marion, Ohio
I would think it is more than that.
Like a license plate on your car. You can get in trouble for putting someone elses, or a fake, plate on your car. The N number on an airplane is the same as a license plate on a car.
Another point....,Is there any reason why you can't register an ultralight as an LSA? In which case you would need a valid N number.
