uAvionix tailBeaconX
pwood66889
Feb 10, 2007
1,532
Sopchoppy, Florida, USA
Absolutely overpriced if one does not need entry into the ADS-B Out airspace.
Not badly priced if one has to go from no transponder up to ADS-B compliant.
$2500 US, plus installation, which doesn't sound like that much. My Type Club had good luck with their units.
7,019
Yes, I was suggesting that it's still expensive but an interesting option if you need to add a transponder and ADS-B to a plane that has neither, not for folks that already have an acceptable transponder.
8,972
$3194 with the required control head.
addicted2climbing
Jan 27, 2012
1,010
Glendale, CA
So with this and the 2" instrument display wonder if I could get away with flying my Zigolo at KWHP. Its right on the edge of the Mode C area and rural enough I might be OK to fly Part 103 out of... Would make controllers pissed a 40mph airplane in the pattern with 150 mph airplanes...
pfarber
Feb 21, 2019
473
Pennsylvania
The head unit, to change the transponder code is a finger dance that is way to difficult. Unless they can improve the xponder code entry part hard pass.
7,019
In the Kitplanes article on this device, the reviewer mounted it inside the tailcone on a Glastar. I wonder if this would work just as well inside a spruce-and-plywood rear fuselage, which would certainly simplify installation in wooden aircraft.
