MauleOwner
I have recently acquired two Hatz projects to sale for the current owner. I do not have the original plan sets or serial numbers at this time but are expected to arrive by courier in the next couple of weeks.
Projects #1 – Hatz Classic – Project began construction in 2005 and ended in 2013. No work on the project sense that time. Complete airframe in the fabric stage. Fuselage and tail feathers covered but not silvered. Wings are not covered. It appears that all airframe components are here, including Maule tailwheel, flying wires, engine mount and cowling, pushrod tubes, brake lines, Cleveland wheels and brakes, etc. Rear instrument panel is complete. Firewall forward was not completed. Radios, ELT, propeller, and 1723 SMOH O-320, will be sold separately. The craftsmanship on this project, from the woodwork, the sheet metal work through the fabric work is some of the best I've seen. https://eaabuilderslog.org and search for projects in the 75754 zip code. Asking $21,500 or best offer.
Project #2 – Hatz Classic fuselage, main gear legs, Matco tail wheel, tail feathers and some fuselage formers. Over 4350 hours on builders log for this project between June of 2010 and December of 2011. Two Technical Counselor Visit Reports during the build. This project has not been primed. A light rust layer is apparent on 2/3’s of the fuselage. Will need blasting and priming as soon as possible. https://eaabuilderslog.org and search for projects in the 75754 zip code. Asking $6500 or best offer.
These projects are located at the Mineola-Wisener Airport (3F9) 22 miles northwest of Tyler, Texas. PM with questions or call Jim at (903)292-7625
