Turtle deck grain direction
Little Scrapper
Jan 3, 2014
5,664
Wisconsin
A or B?
I’m gonna build a turtle deck tomorrow and need to lay it out on mahogany plywood. There’s 4 bulkheads put together with stringers. Standard affair.
Metal is my strength in life, Wood is definitely my weakest link so I’m at a loss here guys. I’m guessing it doesn’t matter but there’s gotta be a slight difference in stiffness?
Which would you pick?
TiPi
Aug 25, 2019
253
Mackay (AUS)
to get the best of both grain directions, I would laminate 2x 1/8" ply at 90deg. This is done on some critical areas like firewall, main spar web etc. That also provides additional stiffness in both directions.
7,899
Highly load places I would do the 2X 1/8" ply for the 1/4". But in the turtle deck , I would go with "B".
Chilton
Jun 28, 2014
88
Arusha
If it will fit on the sheet I would actually go for +/- 45 degree grain, but I doubt it really makes a big difference.
Little Scrapper
Jan 3, 2014
5,664
Wisconsin
I actually had to go with A, turns out TFF was right about fit. I had no choice. Built all 4 bulk heads and they turned out well. Very stiff.
Making the stringers this afternoon.
Appreciate the input, thanks!
