Turbocharged engine options for a 2 seater - what would you consider?
Puggo1
May 19, 2020
31
Hi,
I'm looking at Honda 1.4-1.5 Civic engines. Weight is in your range and power is from 90 to 200hp.
happy flying.
Puggo
aeromomentum
Jan 28, 2014
219
Stuart, FL USA
While older Honda engines (for example D series) were very light, the newer Honda engines (for example L series) tend to be relatively heavy for their size. Some of the iron block Toyota motors (for example SZ series) of the same size are actually lighter weight than newer Honda's.
The Suzuki G series engines are very similar to the Honda D series engines and some parts are actually interchangeable. We have run Honda D series pistons in a Suzuki G series engine and many others have used Honda racing cranks and rods since racing parts for the Honda are more common.
In general, long stroke engines tend to weigh more for a given displacement. Engines with a bore about the same as the stroke tend to be lighter. Of course there are many exceptions.
We have the AM13T that is 140hp, 185lbs and $14K with the standard gearbox. This turbo version has not yet flown but we are working on this. We have 2 turbo AM13's on airboats for over 4 years. Cooling (wet) will add about 10lbs, oil cooler about 5 lbs, intercooler about 10lbs and tailpipe about 3lbs. These are minimums and a more complex installation will add more weight. In any case it should be well under 220lbs installed and provide over 130hp at 9000 MSL.
arj1
Jul 2, 2016
106
UK
@thisadviceisworthles, what about the AeroVee Turbo?
$12.5K, 100HP
Sep 14, 2022
15
Sylvania, Ga
I'm looking at turbo engine options for a 2 seat plane, something along the lines of a Whitman W8.
The big points I would like to consider are:
Under 220lbs installed
Minimum 90hp @ 9000ft DA
Ability to run on pump gas I can buy anywhere (including E10)
Forced induction for consistent takeoff performance
Installed price of under $20K
Some proven time in the air (I don't want to be the first doing this install), with manufacturer support being ideal
My "measuring stick" is the Rotax 914, but I am looking for something with a lower cost to overhaul
My plan is to build this to be my "last plane", so I am looking at per hour cost including overhaul and with a preference for efficiency and ease of
A 3 litre corvair engine will do that and weigh 225 lbs. With a turbo will probably make 150 hp vs 120 hp without turbo. You might want to look at fly corvair for their conversion. It does this direct drive to the prop so the engine
17,941
With an alternative engine the CG of the engine is usually further forward, along with it being heavier, which will change the total CG of the airplane. It may help, hurt, or not matter depending on the plane. A W8 would be very sensitive to it, so you might need to juggle other bits to keep the CG reasonable.
keithkrum
Dec 17, 2021
41
Geo Metro 3 cylinder turbo automotive engine, made about 90 HP IIRC, and the Raven Redrive company made a reduction unit for it to turn a propeller.
Exactly what came to my mind. As I remember, those engines were built by Suzuki. I had one in my old Chevy Sprint. It was very reliable and about the only part of that car that didn't turn to sh$t at 30,000 miles. Great engine though. :D
tcrbaker
Jun 27, 2014
15
New Orleans
My plan is to build this to be my "last plane", so I am looking at per hour cost including overhaul and with a preference for efficiency and ease of running.
I would like to suggest you consider the 3 cylinder 1.5 liter Ford Dragon engine. I have been looking at it for some time and think that it offers a unique set of features that would make for a conversion in the vein of the Whitman Oldsmobile conversion. Here are some of the advantages I see that the Dragon brings to the table:
It is a new design that is readily available at a reasonable price. ( The Dragon is engine used in the base model of the current Ford Escape)
It is all aluminum. (I have not been able to find an exact weight, but it should be under 200 lbs. installed). It is an efficient design with 4 valves and 500 cc per cylinder. It is turbocharged and makes 181 HP @ 6000 RPM. ( Changing the turbo and reprograming the ECU it should be possible to get around 100 HP @ around 3000 RPM so that no PSRU is needed.) I have looked at the design and anticipate that the crank shaft would have to be replaced to provide the necessary thrust acceptance and propeller flange. ( If physical modifications could be limited to a new crank and turbo the cost should be reasonable). It already runs on pump gas. The ignition system is coil on plug. The direct injection injector could be removed and replaced with a second plug to provide the opportunity for dual ignition. The existing port injection would work fine for steady state operation. The cam drive belt is internal and protected. The cylinder deactivation system would be easily removable. It has a balance shaft to cancel the torque imbalance inherent with 3 cylinder motors.
As soon as I can get an engine from a wreck I plan on investigating this conversion further.
rv7charlie
Nov 17, 2014
3,364
Pocahontas MS
A 3 litre corvair engine will do that and weigh 225 lbs. With a turbo will probably make 150 hp vs 120 hp without turbo. You might want to look at fly corvair for their conversion. It does this direct drive to the prop so the engine isn't screaming at 6000 rpm.
At the expense of really high cylinder pressures (stresses on pistons, rods, bearings, crank, valves), and the need for a '5th main bearing' to handle bending loads, and an aftermarket crank, to avoid the fatigue failures experienced by multiple flyers.
Everything's a compromise....
OKDon
Feb 25, 2022
54
rv7charlie
Nov 17, 2014
3,364
Pocahontas MS
Do be sure to tell him that the plane will actually be flown, and not just drag raced. The duty cycle on the STOL stuff like he flies is about 3%. ;-) Remember, he tows the plane in a trailer behind a motor home to the STOL events.
The attraction for me of the setup in the RV9 I linked earlier is that Yamaha did all the development work to make the engine & turbo survive together, all the way up to the 10K' altitude range. That means not having to design 1st the actual turbo specs (auto turbo specs won't work), and then designing/building manifolds, etc that will survive. Those are non-trivial tasks even with NA conversions; adding a turbo to the mix is at least an order of magnitude harder, unless you've already been there done that repeatedly *for aircraft* and can legitimately trust your own skillset.
KeithO
Nov 29, 2009
865
Jackson, MI
Guys the Viking 90 is under $10k in normally aspirated condition. With gearbox, wiring harness exhaust all set up. Its intended to be a Rotax replacement and the same weight. If one is intending to do turbo normalizing or just a bit of boost one could use a pretty small turbo, the big thing would be to prevent it overspeeding at altitude.
9,476
I'm looking at turbo engine options for a 2 seat plane, something along the lines of a Whitman W8...
I too have to question the need for turbo for takeoff performance. Turbos in that power range would have to be developed and made reliable yourself. There are a number of NA engines in your weight range that will still have close 90 hp at altitude.
Now if you want to turbo normalize for altitude performance, knock yourself out. Turbo sizing, oil lines, intercooler sizing, mounting, etc, they can all be done. Ross at SDS writes about it on here as rv6ejguy.
8,417
On a normally aspirated engine with a fixed pitch prop, as we climb and the engine loses power due to the less dense air, the prop also encounters this thinner air and it remains a good "match" resistance for the engine. It will still pull all the way to engine redline. With a turbo, the engine can continue to put out more HP at higher altitude, but the prop may not be able to use that power unless the pitch can be varied. This is one reason aircraft with turbo engines usually have variable pitch props.
Assuming your engine budget is reflective of your general budget, a variable pitch prop probably isn't in the cards.
Now, if your desire for a turbo is just due to your field elevation and you don't expect to fly much lower, the a turbo and fixed pitch would work okay. But I suspect a normally aspirated engine that meets your 90hp at altitude requirement will be easier to implement and less costly.
aeromomentum
Jan 28, 2014
219
Stuart, FL USA
The 3 cylinder 1.2 L Mitsubishi 3A92 is a long stroke engine and even though it is just 3 cylinders and aluminum block it is heavy for it's displacement and power. It actually weighs more that the larger, smoother and more powerful 4 cylinder Suzuki 1.3 L engines.
A 3 cylinder can be and normally are 100% balanced in primary and secondary modes. The strokes are each 120 degrees apart. This is better balance than an inline 4. There is a slight rocking mode and this does become a greater issue with longer stroke engines like the 3A92 but is not normally an issue with a better bore to stroke and rod ratios engines like the 1 L Mitsubishi 3A90. Balance shafts can greatly help but of course add weight. Racers normally replace the balance shaft with a straight no added weight shaft but this is still more weight than not having one. But the larger issue with 3 cylinder engines converted to aircraft use is the torsional vibration. The less power strokes you have the larger they need to be for a given power output. More cylinders, higher RPM and more power strokes make for a torsionally smoother engine.
Jun 20, 2018
25
Las Vegas, NV
Thanks for all of the great information, I am learning a lot.
As for the prop question: right now I am planning for a ground adjustable.
My number one focus of the the turbo would be takeoff performance at high DA airports, but I would like to be able to climb up to 15K and cruise for longer trips.
I am researching other prop options, but what options are available will likely be determined by engine choice.
On a mildly related note: @Areomomentum, on the website for the Veloce 400, when paired with the 300hp AM engine it specs a fixed pitch prop and says "Ask Us Why", but quite annoyingly does not offer any more explanation. Do you know why they suggest a fixed pitch prop with AM20T and constant speed props with the other options?
rv6ejguy
Jun 26, 2012
4,926
Calgary, Alberta, Canada
Having been involved with and flying turbocharged aircraft for around 40 years, there is no way a fixed pitch prop will provide a good compromise between takeoff, climb and cruise at high altitudes. A prop pitched for cruise at 15K will be mostly stalled during takeoff. Plenty of folks have tried it and found out it didn't work well.
You'll note that almost all factory turbocharged aircraft have CS props. The air density at 15,000 feet is close to half of that at SL. Therein lies the problem with the prop if SL power is maintained to that altitude.
IVO and Airmaster may be prop options for you for you.
aeromomentum
Jan 28, 2014
219
Stuart, FL USA
I am sorry for the page being annoying! I am involved with the plane, company and engines but not with the website.
The AM20T can put out over 360hp at MSL and can also put out over 300hp at MSL at just 4800 rpm. We limit the power to 300hp but it is flat from 4800 to 7000. Keep in mind that the "rated power" is at 5800 and the factory red line is 7000 rpm. So even if the fixed pitch or ground adjustable prop is pitched for cruise you will still be able to get full rated power at the start of your takeoff roll and during your climb.
Ross is right about a fixed pitch prop being stalled but this is only during part of the takeoff roll. This does greatly reduce prop efficiency and thrust but due to the high available power and short time this has little impact on takeoff performance. The props are also a little less efficient in climb but in this case the reduced efficiency is much smaller than when they are stalled.
So will it perform better with CS props? Absolutely. But is the difference worth the added cost and added weight? That is up to the builder/owner to decide. For me, it is not since the takeoff/climb performance is already very good even single engine. This is similar to the classic RV-6 choice between the IO-320 with CS or the IO-360 with fixed pitch. And due to the much wider power band of the geared and boosted AM20T the numbers push the choice more to the fixed pitch and higher power side.
Yes, the air is less dense at altitude. But the speed is higher so the mass flow through the prop disk is not reduced as much. For our example if the prop was pitched for 2050 RPM (5000 engine rpm) for MSL cruise, the prop would be at about 2400 RPM (5890 engine rpm) at 30KMSL cruise. This would not be acceptable for a direct drive engine especially a turbo direct drive engine! But for the geared and boosted AM20T it is not only acceptable it is actually needed since the AM20T needs to turn a little faster at altitude to make the rated power.
There is also other precedent for fixed pitch props on high speed aircraft. Look at the Schneider Trophy aircraft of the 1930's. They had very high pitch fixed pitch props and they had the added issue of needing to get on step and takeoff from the water. Some had speed records of over 400 mph with their fixed pitch props and high drag floats. Most later aircraft used geared and boosted engines.
rv6ejguy
Jun 26, 2012
4,926
An interesting discussion.
The RR R engine developed 2000-2600 HP so given the weight of the S.6B airframe, the power loading is a little over 2 pounds/hp. The M.C. 72 had an even better power loading. These are in a different league from the aircraft we are discussing here which are at around 9 pounds/hp. In addition, these aircraft raced at sea level so the props could be optimized for max speed at one altitude and takeoff and climb were unimportant. Those last two things ARE important for most GA aircraft.
Not only does thrust drop off considerably with stalled blades but drag, hence input power required, massively increases. We've seen this first hand when running engines on the test stand with a variety of props and test clubs.
I'm curious to know if the Veloce 400 has flown at 18,000 feet yet with the AM20T and FP prop? What is the TO distance and ROC?
