tube straightening
Discussion in 'Workshop Tips and Secrets / Tools' started by antimarx, Mar 9, 2018.
  1. Mar 9, 2018 #1
    antimarx
    antimarx
    antimarx
    Feb 22, 2015
    11
    0
    Ann Arbor, MI
    I have an engine mount [chro-mo] for a 1/2 VW -2 tubes are bent about 45 degrees. I would like to straighten it with heat to use as a test stand. Feasible?
  2. Mar 9, 2018 #2
    11,551
    3,231
    For a test stand, probably. You have to look how bad the mount is stretched or kinked when straight. Might need reinforcing if you are going to put a lot of time on the stand.
  3. Mar 9, 2018 #3
    3,716
    1,079
    might try cut and fish-mouth splice, done properly, you might use it in an aircraft.
  4. Mar 10, 2018 #4
    dino
    dino
    dino
    Sep 18, 2007
    586
    81
    florida
    Not worth the time. Use the straight pieces for something else and go with electrical conduit tube or similar for the stand.
  5. May 15, 2018 #5
    Armilite
    Armilite
    Armilite
    Sep 6, 2011
    3,022
    244
    AMES, IA USA
    Steel is cheap at Scrap Yards 10 cents a pound. There are many VW Engine Test Stands and Plans out there.
    http://www.darrylsgarage.com/912/teststnd.htm
    https://www.thesamba.com/vw/forum/viewtopic.php?t=288599&start=220
    https://rennlist.com/forums/964-forum/840581-how-to-build-your-own-engine-stand-vw-643-a.html
    If you don't have the Tools to make your own.
    https://www.ebay.com/itm/Mobile-Eng...224918?hash=item41dfe55cd6:g:zNMAAOSwGYVXC-Ub
    Cheap Stand.
    https://www.ebay.com/itm/Engine-Stand-for-VW/232742218118?hash=item3630846986:g:qSQAAOSwo2la26U~
    Good Engine Stand.
    https://www.harborfreight.com/2000-lb-capacity-foldable-engine-stand-69521.html
  6. May 16, 2018 #6
    Turd Ferguson
    Turd Ferguson
    Turd Ferguson
    Mar 14, 2008
    4,736
    1,669
    Upper midwest in a house
    absolutely
    proppastie likes this.
