Trying to achieve turbonormalizing the home-built way
Discussion in 'Firewall Forward / Props / Fuel system' started by geosnooker2000, Aug 11, 2019.
  1. Aug 20, 2019 #61
    SVSUSteve
    SVSUSteve
    SVSUSteve
    Aug 21, 2007
    3,854
    915
    Indianapolis, IN
  2. Aug 20, 2019 #62
    9,334
    6,111
  3. Aug 20, 2019 #63
    rv6ejguy
    rv6ejguy
    rv6ejguy
    Jun 26, 2012
    3,749
    2,776
    Calgary, Alberta, Canada
    Vne regarding flutter is based on TAS, not IAS. Lots of articles on Van's aircraft discussing this.
  4. Aug 20, 2019 #64
    9,334
    6,111
    Yup, lots of incorrect guesses, opinions, and beliefs on this subject everywhere. Most are wrong.
  5. Aug 20, 2019 #65
    Turd Ferguson
    Turd Ferguson
    Turd Ferguson
    Mar 14, 2008
    4,672
    1,635
    Upper midwest in a house
    I have flown some planes that had chart to adjust the value of of the placarded Vne. Did they not get the memo Vne is always the same indicated value?
    A glass cockpit airplane can adjust where Vne is displayed as you fly. All with the magic of electrons.
    pictsidhe likes this.
  6. Aug 20, 2019 #66
    geosnooker2000
    geosnooker2000
    geosnooker2000
    Mar 30, 2019
    100
    10
    Somerville, TN
    Here they are. In both cases, the info is on page 5-24 (cruise performance)
    https://inflightpilottraining.com/wp-content/uploads/2018/12/SR22-POH.pdf
    http://takeflightsandiego.com/assets/documents/SR22T G5 POH.pdf
    Note the differences on pages 2-4 (Airspeed limitations). They ARE represented in KIAS, not in KTAS. For the turbo, at least, I suppose if they had gone with KTAS, they wouldn't have needed two different values in the table.
  7. Aug 20, 2019 #67
    6,437
    1,672
    IAS is what the gauges tell you in an aircraft. It is easier to hit Vne up high, so it ia likely specified in terms of IAS as high as Vne could be achieved. Increase your ceiling, that IAS Vne is no longer safe. Maybe it will be ok, maybe your wings will buzz off. Do you really want to assume it will be fine?
    Change anything, it's a new plane, and needs to be tested as such. The 'oh, it'll be fine' attitude to deviations from standard kills a lot of experimenters.
  8. Aug 20, 2019 #68
    SVSUSteve
    SVSUSteve
    SVSUSteve
    Aug 21, 2007
    3,854
    915
    Indianapolis, IN
    I stand somewhat corrected as I was simply referring to the IAS readingS that are published in POHs. However, if you’re just plodding along smashing bugs, that line on the ASI should be sufficient (assuming that the design has been properly tested). Obviously, if you’re going up into the flight levels etc you have to be more careful and account for changes etc. You know that I am the person on this forum least likely to advocate a cavalier attitude with regards to safety. I apologize if it came across that I was doing so.
  9. Aug 20, 2019 #69
    Turd Ferguson
    Turd Ferguson
    Turd Ferguson
    Mar 14, 2008
    4,672
    1,635
    The turbo handbook says Vne is reduced linearly from 17,500 feet to 25,000 feet. 205 to 175. What is that suggesting?
    Being a Part 23 airplane a Cirrus had to publish IAS numbers to comply with the regs. That doesn't change the applicable laws of physics. They have enough margin build into the plane that the difference between IAS and TAS is irrelevant - at least till you get to 18,000 ft.
  10. Aug 20, 2019 #70
    11,435
    3,176
    When you are flying, your airspeed gauge will read KIAS only. You have to calculate KTAS for your conditions. Now with the Cirrus and any glass cocpit, its done for you. But the Cirrus has the table which is nice, in chapter 5. The pilot has to juggle all the limitations even if he could go faster. One day you could the next you can't. If you made the same table and put in your airframe limitations, you will be caping out once the true airspeed crosses with the VNE, because the VNE is low. At some point the gains stop if you believe in the boundrys. The Cirrus have 205 KTS VNE at sealevel. Thats 236MPH. Above 17500 they have to use 175 indicated; big correction.
    SVSUSteve likes this.
  11. Aug 20, 2019 #71
    Turd Ferguson
    Turd Ferguson
    Turd Ferguson
    Mar 14, 2008
    4,672
    1,635
    As you climb, indicated airspeed decreases; (ref "q") Dynamic pressure decreases which is what your airspeed system is measuring.
    The going rate is ~2% per thousand feet but it is not linear, especially when you get above 18,000 ft.
    Since indicated airspeed moves further away from the fixed value painted on the scale as you climb, it is harder to "hit Vne up high" with indicated airspeed.
  12. Aug 20, 2019 #72
    rv6ejguy
    rv6ejguy
    rv6ejguy
    Jun 26, 2012
    3,749
    2,776
    Many turboprops and jets have a Barber Pole on the ASI which shows Vne corrected for altitude. This is because Vne isn't based on IAS regarding flutter.
    IAS is close enough for most slow planes flying below 10,000 feet. It isn't close enough up in the flight levels.
  13. Aug 20, 2019 #73
    9,334
    6,111
    And, if Vne is set by flutter, the difference between IAS and flutter speed.
  14. Aug 20, 2019 #74
    rv6ejguy
    rv6ejguy
    rv6ejguy
    Jun 26, 2012
    3,749
    2,776
    I had a hand in two RV7s fitted with turbo Subaru engines. These would easily bust Vne (210 KTAS) at anything above 10,000 feet in level flight with modest manifold pressure- say over 40 inches. Planes with low Vnes are not the best candidates for operating high with turbochargers. Can be done if careful but sometimes it's better to choose a different airframe, better suited to the fast mission.
    BJC likes this.
  15. Aug 20, 2019 #75
    E28POWERM20
    E28POWERM20
    E28POWERM20
    Sep 1, 2016
    103
    21
    Hillsboro, OR
    A BD-4 with a turbo would be very attractive here. The current BD-4C version has a 261mph VNE. You can even build it with longer wings for better high altitude performance. Can be built from plans as well.
    If you don't need 4 seats, the options really start to open up.
  16. Aug 20, 2019 #76
    6,437
    1,672
    What is the Vne on the long wing version?
  17. Aug 20, 2019 #77
    E28POWERM20
    E28POWERM20
    E28POWERM20
    Sep 1, 2016
    103
    21
    Hillsboro, OR
    That's a good question, I only know it's an option.
    Edit: The VNE is still 261mph with the longer wings, but only at 2000lb gross weights and lower. No testing was ever done at higher gross weights.
    Source: Bede Representative.
  18. Aug 20, 2019 #78
    BoKu
    BoKu
    BoKu
    Aug 16, 2013
    2,251
    2,805
    Western US
    Have a chat with Steve Smith about this at the races. He has a compelling argument, backed with some research, that tying flutter-bound Vne to TAS is unnecessarily conservative. It appears that a value that splits the difference between TAS and IAS is more generally applicable.
  19. Aug 20, 2019 #79
    SVSUSteve
    SVSUSteve
    SVSUSteve
    Aug 21, 2007
    3,854
    915
    Indianapolis, IN
    Can you elaborate on why that might be?
  20. Aug 20, 2019 #80
    BoKu
    BoKu
    BoKu
    Aug 16, 2013
    2,251
    2,805
    Western US
    Sorry, that is aerodynamics above my pay grade. I'll ping Dr. Smith and see if he can send me a link.
