Tri-Mower Design
TiPi
Aug 25, 2019
244
Mackay (AUS)
I bought one of these Tillotson 212cc engines last December. I've got it mounted to an engine test stand for experimentation. I recently bought an Xoar 36x12 propeller to test with it. It should take 9 HP at 4050 RPM and 10 HP at 4200 RPM, but I need to figure out how I'm going to mount the propeller before I can proceed with any testing to verify any of this.
My first attempt was to draw up in CAD a custom propeller interface to mount to the shaft. However, having the parts made as I drew them is going to cost a bit more than the engine, so I'm looking at different designs now and other alternatives. If anyone has good advice on how to inexpensively add a propeller interface to a 3/4" straight keyed engine shaft, I'd sure like to know about it.
I figure there is about a 50/50 chance this engine investigation is a wild goose chase, but maybe it will bare fruit in the long run. Couped with the right design, it has the potential to be part of a very affordable ultralight.
for testing purposes, I use a V-belt pulley with the appropriate Taper-Lock adaptor. In your case (3/4" shaft), probably a 1210 or 1610 Taper-Lock and a single-groove pulley where the bottom of the groove is larger than your prop bolt PDC. Single chain sprockets can also work. Then mark the PDC and drill&tap the holes.
mcrae0104
Oct 27, 2009
3,210
I can get a student pilot certificate and get to the point where I'm signed off to solo the plane. I can then solo it as a student pilot, indefinitely.
Take a look at the restrictions on student pilot solo flight in the FARs. You might decide that getting instruction every 90 days isn't very convenient to do indefinitely.
blane.c
Jun 27, 2015
3,848
capital district NY
I am getting the drift that if you build a "glider" whether it is motorized by a gazillion engines/motors or none you do not need a pilot certificate to fly it solo. Not any EAB glider, just the one's you build and license yourself.
I am wondering why more people don't register there aircraft as gliders. I guess it is a pain to get a glider license if you want to haul passengers.
