Trace based simplified composite analysis. Opinions?
stanislavz
Aug 21, 2016
927
Lt
Even the same tech at the same temperature and humidity laying up the same part can have variations in the quality and consistency of each layup.
Same was written by Jim Marske in comparision of carbon fibre spar as designed to tested ones.. And solution of pultruded carbon rob come to live. And no, it is not expensive at all.
stanislavz
Aug 21, 2016
927
Lt
Inspired by Caro wing. An comparison of wing skins for chord 1300mm, 13.5% thick. Piece of span 750 mm.
Foam less :
Reinforcement ribs load :
Ribs :
Laminas :
With foam :
Load and boundary condition
Load is shown inccorectly, its starts from 0.006N/mm2 at the nose and ends at leading edge. Formula is z=(1300-y)/1300/-0.006
For easier calculation, nose section was ommited, and reinforcements were modelled as section with know property.
And yes, it would look different for single spar wing.
stanislavz
Aug 21, 2016
927
Lt
Once more, this time for full section, for strut braced wing with jury struts. Only one section
with foam
span is 1300 mm, weighs are 5.17 kg for section with foam, and 5.6 for section without foam. In real world , with foam will be bigger ?
Deflection is close, but not similar. Mine tubes weight 0.066 kg per m, and this same as ribs from two plies of 300 gsm..
stanislavz
Aug 21, 2016
927
Lt
Added two more ribs, but made all five from 2 plies of 300gsm biax, in stead of 4:
stanislavz
Aug 21, 2016
927
Lt
One more run, to minimize parts / operations counts.
Two spar wing, Front is core/rib less D cell, first spar is place ad 120 mm, of 1300 mm chord wing. It is build from two layers of 300 gsm biax of main skin + 2 x 300 ud at 90 degree for rigidity.
From front spar to rear spar - only 300 gsm skin + rib each 200mm.. Ribs olso build from 300 gsm biax.
Skin with front D cell molded as one piece, ribs/shear webs molded in place. With some corrugations for buckling stability.
It shows ~ 10 kg for skin and ribs, per wing for 12.5 m2 wing..
Fireflyer228
Aug 17, 2020
24
Oregon, USA
My last post on this thread. On my phone it looked like it was recent and on this website I can't edit my posts after a few minutes. It makes me a little crazy when I re-read my posts and it looks like a child wrote it. Sorry for my random post. I didn't mean to detract from the topic. I won't be doing that again.
stanislavz
Aug 21, 2016
927
Lt
Did some literature overview - if single skin is used as fabric replacement (non-load bearing, heavy ribs underside), and most numbers looks like this for fiberglass - skin done from two layers of 10 oz / 300gsm fabric with ribs spaces from 225 to 300 mm. Aircraf reviewed - bd4 (recomennded to add one more layer / or rib ), ol' ironoside, Maerske monarch (300mm of ribs spacing in first versions, reduced 225 mm in later ones), Strojnik S4 (250mm, laminar flow).
And, yes it did holds air loads, and planes are ok with this solution, some were able to have laminar flow.
But - here goes the champion from other side - Cri-cri. 0.5mm aluminium skin, bonded to 6mm pvc foam ribs spaced each 45/90 mm.
And results, which are fun to me. A direct comparison of aluminum to black aluminum (0.5mm skin to 0.5mm skin) :
Winner is black aluminum.
stanislavz
Aug 21, 2016
927
Lt
More on wing skins. As one of my teacher learn me - you result in fea is as good as model you did described.
So on wing skin - i did remember of my first airplane, it have ugly airfoil, done from two radiuses :
Same simplified model drawn for GA 30-413.5, 1.35m chord.
And radiuses are :
