A couple of questions: What configuration of toggle switch (SPST, SPDT, etc) would I need to do the following: Down position - Off - Input not connected to any output Center position - Low - Input connected to one output Up position - High - Input connected to second output This would be used to feed a strobe power supply that offers both a low and a high output. A source of supply for this switch would also be appreciated. Second question: The Rotax 503 wiring diagram calls for a 15-amp fuse between the rectifier-regulator and the positive battery terminal. Would there be any reason not to use a combination toggle switch/circuit breaker, such as the W31X2M1G-15 from Wicks Aircraft Supply for this purpose? Thank you!
It would be much easier, and perfectly acceptable, to do it this way: UP = HIGH MIDDLE = OFF DOWN = LOW A simpl SPDT with a center position OFF would work. These are available at Chief Aircraft, Wicks, Aircraft Spruce, Digikey, Jameco, to name a few. Waiter
Stupid, I know, but since all of the other switches will be "down" when "off", I would like to keep things consistent...
Hey, NO PROBLEM. Try Mouser Electronics: www.mouser.com Search for "ON-ON-ON Toggle Switch" This should turn up a few candidates. I looked at one in particular that should work in your application: http://www.nteinc.com/switches/pdf/pg4.pdf 54-362 - Spade Terminal 54-371 - Screw terminal Good Luck Waiter
