Titanium
Discussion in 'Sheet Metal' started by cheapracer, Nov 7, 2019.
  1. Nov 7, 2019 #1
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,328
    3,580
    Australian
    Does anyone here know much about Titanium?
    There is quite a bit for sale around where I am, Grade 2 mostly as far as I can tell, but higher as well.
    I realise the grade is low means it's lower quality, but what should I know further? Is it still as strong as steel at half the weight etc?
    Is there a grade I should be aiming at for 'general aircraft use' (relative), like you would generally use 4130 if steel, or 6061/2024 if aluminium?
    Not much discussion about it, are there drawback or just too expensive for general use that scares people off?
  2. Nov 7, 2019 #2
    Riggerrob
    Riggerrob
    Riggerrob
    Sep 9, 2014
    1,174
    328
    Canada
    Titanium is most valuable in hot areas. That is why some builders like to install titanium firewalls behind their engines.
    Titanium rods also have special flexibility, which is why a few kit factories offer them as Wittman-style spring landing gear legs.
    cheapracer likes this.
  3. Nov 7, 2019 #3
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,328
    3,580
    Australian
    Thanks, sounds like one use for it, I'll look into the heat part as I was going to use stainless, and it's a big piece heavy of course.
  4. Nov 7, 2019 #4
    12,042
    2,347
    I got some titanium rods at the scrap yard. My lathe couldn't machine it. Too hard.
  5. Nov 7, 2019 #5
    Angusnofangus
    Angusnofangus
    Angusnofangus
    Sep 29, 2015
    329
    143
    Victoria, Canada
    I haven't worked with titanium for awhile, but IIRC, the stuff we were using was Grade 5 (https://continentalsteel.com/titanium/grades/), and it was just used for firewalls. Sometimes those firewalls doubled as aircraft skin. Case in point, Sikorsky S-61's, the fuselage skin under the engines is also a firewall, therefore it is titanium. Aluminum is much easier to work with, besides being a lot cheaper. Personally, I don't see much much of a case for using titanium, except for firewalls.
    proppastie and cheapracer like this.
  6. Nov 7, 2019 #6
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,328
    3,580
    Australian
    Thanks, I would only be laser cutting and folding 1/8" sheet I think.
    I guess I should ask then: Does it fold ok? Yes I can look on the net, but often first hand experience differs from theory, as many of us well know.
  7. Nov 7, 2019 #7
    Angusnofangus
    Angusnofangus
    Angusnofangus
    Sep 29, 2015
    329
    143
    Victoria, Canada
    The stuff I've worked with had a lot of springback when bending, Folding over .125 sheet would have been impossible with that alloy. Don't know about softer stuff.
  8. Nov 7, 2019 #8
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,328
    3,580
    Australian
    center wing spars, fuse corner load plates, seatbelt mounts, landing gear mounts, rudder quadrant
    There's a few possibilties, but yes, comes down to economics as well. Just thought i would ask before I went looking the next few days, thanks for replying.
  9. Nov 7, 2019 #9
    Super Moderator Staff Member
    Apr 4, 2007
    8,625
    3,011
    Grade 2 titanium isn't "lower quality"; it's commercially pure titanium, as opposed to grade 5 which is a titanium-aluminum-vanadium and higher strength.
    Very roughly, titanium has mechanical and thermal properties comparable to stainless steel at 2/3 the weight. But the elastic modulus is lower, closer to that of aluminum, at twice the weight of aluminum. Bike makers like it for its "springiness" compared to a similar strength steel or aluminum frame. It's a ***** to machine, and requires special techniques to weld.
  10. Nov 7, 2019 #10
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,328
    3,580
    Australian
    Thanks Dana. Yeah I knew about the welding problems.
    It maybe twice the weight of aluminium, but, like steel, you need to use less of it. Ends up somewhere near the same weight for a large increase in strength over aluminium, happy to be corrected, here to learn ...
    There's really big differences between the grades ..
  11. Nov 7, 2019 #11
    6,858
    1,844
    It's a royal PITA to work with. I suggest you buy a few bits and play with them.
  12. Nov 7, 2019 #12
    12,042
    2,347
    If the elastic modulus is similar to aluminum, as Dana said, then your beam caps will need about the same thickness for buckling in compression. Could be heavier.
    BoKu and cheapracer like this.
  13. Nov 7, 2019 #13
    pilot103
    pilot103
    pilot103
    May 13, 2003
    100
    20
    Titanium isn't harder to work with just different. I spent 35 years certified to weld everything from A ( aluminum)to Z (zirconium). It was by far my favorite thing to weld. I have machined it and prefer it to stainless. IT is also very expensive.
  14. Nov 7, 2019 #14
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,328
    3,580
    Australian
  15. Nov 7, 2019 #15
    Toobuilder
    Toobuilder
    Toobuilder
    Jan 20, 2010
    4,447
    3,246
    Mojave, Ca
    I have access to scrap from my employers and it's almost exclusively 6AL-4V. It's incredibly difficult to bend and takes special care to prevent cracks. I made a "L" angle out of paper thin .016 Ti and it took a LOT of force on the brake to bend even a 30 inch section.
    Can be drilled and machined in a home shop with sharp tools and technique.
    It's magic stuff though.
  16. Nov 7, 2019 #16
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,328
    3,580
    Australian
    Yeah, looking on the net doesn't give me much hope of bending 1/8" successfullly, most suggest heating to do it.
    Anyway, was just a thought experiment, a rough estimate looks like a 4' x 8' x 1/8" sheet might cost the same as 25 sheets of 0.020" did ...
  17. Nov 7, 2019 #17
    Doggzilla
    Doggzilla
    Doggzilla
    Jun 2, 2013
    1,894
    397
    Everywhere USA
    Go check out how bicycle builders work with it. Incredibly difficult to properly bend or mold.
    For complex shapes they cut and weld instead of bend. That’s why you almost never see anything but straight tubes and beams with welds all over the place.
    If you bend it you have to repeatedly heat treat it after minor bends, which is a royal PIA.
  18. Nov 8, 2019 #18
    Jimstix
    Jimstix
    Jimstix
    Sep 29, 2012
    110
    43
    LAS CRUCES NM
    Must be sawn very slowly to avoid work-hardening.
