Chuchuf
Available is a NEW 0 hrs Continental Titan IOX370 engine. 9.6:1 compression, 200 HP
Factory Log, build sheet and Factory "run in" sheet available.
Optional cylinder walls are electro plated with the Nickel + Carbide (NiC3) process. Valves are parallel valve.
I have the crates so they can be shipped or if you want to come by and pickup in the Atlanta GA area you are certainly welcome.
There should be about 1 year of factory warranty left on the motors according to Titan (From delivery, there is a 1 year grace period before the warranty starts and then a 2 year full warranty and a 5 year warranty on the cylinder barrels for wear or corrosion.)
The EFII is the previous model (which was superseded by the system 32 about a year ago) which has a few hundred out there running. This system would be fine on the engine but can be upgraded for $2300 if you want the latest and greatest. What would be replaced is:
System32 ECUs
System32 Cockpit Controller
System32 Crank Trigger
System32 Main Wire harness
Our bill on these engines was almost $32,000 plus shipping.
We will sell as is for $25,500 plus shipping. I have two of these available one in blue and the other the traditional black/grey.
If interested you can contact me at [email protected]
Thanks
System32 ECUs
Thanks
