The state of the Art?
Discussion in 'Electric Propulsion' started by Foundationer, Mar 10, 2019.
  1. Mar 10, 2019 #1
    Foundationer
    Foundationer
    Foundationer
    Nov 29, 2016
    203
    95
    London
    Seeing as we have this shiny new forum to fill with rabid fan boy rantings I thought it might be an idea to start with some links to successful electric homebuilt airplanes. The more detail on motor/ESC/batteries the better!
    I'll start with Dale Kremer whose E-Lazair project in a lot of ways probably put the lightbulb over people's heads re. This being achievable.
    https://www.rcgroups.com/forums/showthread.php?1412424-100-scale-Electric-Lazair
  2. Mar 10, 2019 #2
    Foundationer
    Foundationer
    Foundationer
    Nov 29, 2016
    203
    95
    London
  3. Mar 10, 2019 #3
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,223
    1,444
    Marion, Ohio
    From what I can see he never got out of ground effect.
  4. Mar 10, 2019 #4
    Foundationer
    Foundationer
    Foundationer
    Nov 29, 2016
    203
    95
    London
    But he was flying in ground effect! Plus, given how that thing was built, I think it's for the best he didn't go any higher!
    MadRocketScientist likes this.
  5. Mar 10, 2019 #5
    radfordc
    radfordc
    radfordc
    Feb 5, 2008
    1,258
    511
    You just need to see the right video clip. Look here starting at 6:00: https://youtu.be/x-9uLPIxrGE
  6. Mar 10, 2019 #6
  7. Mar 10, 2019 #7
    2,976
    1,677
    Peter is a member here who usually posts in the Ultralight sub-forum. With his experience in electric I’d like to see him post here too though I imagine he’s pretty busy.
  8. Mar 17, 2019 #8
    John.Roo
    John.Roo
    John.Roo
    Oct 8, 2013
    239
    167
    Letohrad / Czech Republic
    I have to edit WIKIPEDIA - Phoenix projects are not listed....
    Phoenix Air - developing airplanes with electric propulsion since 2010 :)
    First flight of Phoenix D-14 in 2011
    https://youtu.be/f-VjNI-2fJo
    LiFePO battery at the beginning, than Li-Po battery with capacity 5,5 kWh, later 7,8 kWh. Motor 33 kW air cooled outrunner.
    More about D-14 project - it is movie filmed for Czech Television (ENG subtitles done by myself so I apologize for lower translation quality)
    https://youtu.be/QlkDs9m43Zk
    I really enjoyed also legendary formation flight of 3 electric projects in Grenchen 2018.
    New elektra Phoenix U-15/17E test flown in 2018
    https://youtu.be/y6CU8cfcYN4
    Battery Li-Ion 35kWh, endurance 2,5 h + 30 min reserve. 60 kW watercooled outrunner motor.
    Weather is improving so next week we will continue with flight tests - I am really eager :)
    Best regards!
    Martin
    Foundationer and Himat like this.
  9. Mar 22, 2019 #9
    John.Roo
    John.Roo
    John.Roo
    Oct 8, 2013
    239
    167
  10. Mar 22, 2019 #10
    Exian
    Exian
    Exian
    Jul 26, 2018
    25
    43
    BORDEAUX
    Dear Martin,
    What is the weight of your 35kWh Li-Ion Battery pack?
    Considering an energy density of 250Wh/kg I get a weight of 140kg!
  11. Mar 23, 2019 #11
    John.Roo
    John.Roo
    John.Roo
    Oct 8, 2013
    239
    167
    Hello dear Arnaud!
    Your calculation is practically exact :)
    To keep same CG we replaced weight of fuel in fuel tanks (2x 40 kg of cells) and installation weight of Rotax in the front (1x 70 kg of cells). All together 150 kg.
    For comparizon - on first elektra I had at the beginning 34 kg battery (5.5 kWh) and after has ben done small upgrade to 50 kg (7.8 kWh).
    By the way...
    I found interesting photo of one beautifull one-seater on this page :)
    https://woelfle-engineering.com/
    Best regards!
    Martin
