The Ranger, an easily built high wing LSA runabout
erkki67
Feb 18, 2010
1,893
From the backrest or a wall, measured I’ve 127cm of leg length, if the legs would be straight on the ground.
My sitting height from the bottom to the top of my head is 97cm, also measured, while sitting on the ground against a wall.
But for this I’ll build first this mock-up, and then we will see 1:1 what is the matter.
Marc W
Mar 31, 2017
391
Colorado
Interesting! I am just over 6' tall. When I sit with my back against the wall, the top of my head is also 38-3/16", or 97cm, from the floor. I usually don't have a problem with leg room but most homebuilts don't have enough head room. I have big feet too. I wear 13's or 14's depending on the brand. I have a special pair of shoes that I wear when I fly that don't have a lot of sole sticking out to catch on stuff under the panel.
FritzW
Jan 30, 2011
3,855
Las Cruces, NM
I'm 6'2", size 14 and I "park my Cadillac in the garage" (a nice way a saying I could stand to loose a pound or 50).
Headroom2.jpg Headroom.jpg There should be enough room, even for big folks. My fearless crash test dummy is 6'2" and has perfect posture. Sitting like a real human buys you an inch or two.
1EAEA495-E4DB-4025-A376-5A32492B88BD.jpg Erkki's sitting like a real human. If he sat at attention like the pilot model his head would go through the roof. That mock up almost looks like the first wood CE, if you still have the drawings I could overlay them on the Ranger and see what it looks like
...but if the Ranger has to be bigger, it has to be bigger. Easy enough to do at this stage.
On another note. I heard back from Grove, a set of free standing gear for the Ranger would be $1,400. I would be happy to go that route for a set of plug and play gear but it is painfully pricey.
On another, another note. I talked to Mary (super nice lady) at Carlson Aircraft yesterday to make sure they were still in business (they've been trying to sell the company for a while). They're still in business and fully stocked with all their spars and struts.
...this is where the tube spar guys light their torches and grab their pitchforks
I did a quick comparison between tube spars and extruded I beam spars looking at cost, weight, strength, availability (in the U.S.) and ease of messing with (the data might make an interesting, separate, thread). ...anyway, my tube spar wing idea turned into an I beam wing idea.
Ranger ribs3  1.jpg Ranger ribs3  2.jpg Ranger LE3  1.jpg Ranger wing3 2.jpg XEPS foam (I think). It would require a 48" CNC machine with at least 4" of Z travel. Any machine will plow though foam as fast as you want to run it. It would be super fast/easy/cheap to build, very light and strong. Perfect for hauling big guys out to the sticks on a hot bumpy day.
7,905
Since we all are different its impossible to try to come up with dimensions for everyone. I have a long torso and arms and shorter legs, I need a longer distance for head room and usually have little trouble with the leg room. Bob Barrows is the opposite, with long legs and a shorter torse but we are about the same height. I built the SSSC to fit me and he couldn't get his knees under the instrument panel.
With the JMR, I built the prototype for a lot of headroom to fit me. Someone else my want to build the 1.5" shorter cabin model .
Could you have plans or kits were people would have a choice in different dimensions up to a certain amount ?
7,905
Wouldn't Cub type of main gear be lighter in the complete installation and far cheaper in cost ?
7,091
To the malicious drooling toothless hordes advocating tube spars... I see your picthfork and raise you a trebuchet :)
The I-beam spar wins any and every contest where structural efficiency and G-loading is important... like when it's my corpulent arse suspended up above the Earth!
Please do continue with the investigation and rendering of a Ranger version using Carlson I-beam spars and struts.
addicted2climbing
Jan 27, 2012
1,042
Glendale, CA
Fritz,
How are the foam ribs attached to the Carlson spar? Are the ribs capped in Plywood and glued in place? Being from the Tubular spar camp I can put my pitchfork down and see how this plays out. My only concern is Tubes can be found anywhere on all sides of the planet. What happens if Carlson closes for good or a builder does not want to pay to have spars shipped to Europe. For example, the only thing stopping me from building the Demoichelle was the difficulty in getting the custom spar and no equivalent here.
Love seeing this come together.
Wayne
Jan 14, 2013
428
Chicago, IL
Can you please make the rudder pedals adjustable so that handsome short chubby guys can fly the Ranger as well? I'm a foot shorter than you guys but at least I don't give up any weight to yoj!
FritzW
Jan 30, 2011
3,855
Las Cruces, NM
What good do foam ribs do?
They're strong, light, cheap and easy. Two sheets of 3/4" XPS from Lowes and an afternoon and you've got all your ribs ready to slide on to the spars ...at about $1.50 per rib, even for the deluxe v 2.0 ribs with 1/16" ply spar doublers (see below). No bending, fluting, stapling, sanding, clamping, drilling, deburring, clecoing, riveting, etc.
If you are Cnc cutting the ribs the difference is very small.
As opposed to what? If your talking about wood or aluminum the difference is huge. With foam there's almost no cutting force on the tool, you can make a 3/4" deep cut in one pass going as fast as your bit can remove the shavings and make the corners. Because of the low tool force you can hold down a 4x8 sheet of foam with 4 or 5 drywall screws as opposed to the 7,383,296 1/2" tacks that the 1/8 ply sheets will need. On my machine the limiting speed is the speed I can move the 200 lb gantry around without the machine dancing all over the garage (inertia) ...if I hit the emergency stop button when the gantry is moving pretty fast the neighbors call to see what happened :shock:
Ranger ribs4  2.jpg Ranger ribs4  1.jpg ...the 'bother to worth' of the ply doublers on the spars probably isn't worth it.
Ranger wing3 3b.jpg ...maybe on the root rib where hangar rash tends to concentrate.
FritzW
Jan 30, 2011
3,855
Las Cruces, NM
The rudder pedals mount to blocks glued to the longerons. There would be 5 or 6 inches of play on where to mount them, but I think the primary leg room adjustment will be how much you bend your knees. ...maybe several different holes in the blocks to slide the pedal tube through? ...with adjustable links on the rudder cables?
Welded gear would be cheaper and lighter, and probably a better idea. I just hate the thought of cutting out and filing all those little parts. I guess if they were water jetted it'd be no big deal.
I'd probably glue the ribs to the spars with T-88 thickened with micro balloons. In real life something like Liquid Nails would do it. (if it doesn't attack the foam or aluminum).
Yep, the only downside to Carlson spars is shipping outside the U.S. would be a killer. The time honored "L angles with a sheet web and a bucket of pop-rivets" spar would work also.
7,091
I must be missing something. Wouldn't be the first time!
Are you saying that Expanded Polystyrene FOAM wing ribs are structurally capable of taking all of the air loads and transmitting those loads into the spars ? Are you saying that these foam ribs will be attached to aluminum spars using glue?
Neither of those two concepts makes sense to me. I have plenty of flight time in airplanes where plastic foam is used as part of the structure, but not without a large amount of reinforcement.
I guess I'd like to see the sandbag load test data on a foam wing rib, compared to the (known) data on the sandbag load test of a wood rib or an aluminum rib.
FritzW
Jan 30, 2011
3,855
Las Cruces, NM
Yes, and Yes. Just like countless other airplanes in this performance range. Take a look at your Texas Parasol plans or the Lil' Breezy pictures on page 11 of the old thread that one even looks like it has foam spar webs. Foam ribs aren't anything new, Google "foam ribs on ultralight airplanes".
addicted2climbing
Jan 27, 2012
1,042
Glendale, CA
The Demoichelle uses foam ribs and only has a doubler around the cutout for the spar for glue. Than there is the affordaplane as well....
7,170
Fritz's foam rib makes me wonder about alternative fabrication methods without CNC equipment....
What about adding metal strips to the edges of plywood forms to make big cookie-cutters and/or making up simple male/female molds to make formed and/or corrugated foam shapes with a light hydraulic press or even a rubber mallet?
That way, one person with a CNC machine (or an individual working carefully from drawings) could make the "tooling" to allow builders without CNC equipment to make consistent, accurate ribs.
