The Ranger, an easily built high wing LSA runabout
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by Victor Bravo, Feb 19, 2019.
  1. Jul 8, 2019 #861
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,747
    3,357
    Las Cruces, NM
    Since I've been spending so much time ranting on the APlane thread I thought I'd better post an update on the Ranger.
    I'm not proud of it but I decided to go with store bought AS&S Spruce for the longerons, spar caps and geodesic. I wanted to use lumber yard Pine and Doug Fir but I got lazy.
    That should be enough Spruce for two or three Rangers. Also the wing trailing edges and the rudder tube.
    Since there's really not enough room in my garage to build two airplanes (and the Neirrh was there first) I'm going to do the actual building out at the chapter hangar, I'm there every day anyway.. We're cleaning up from our Waiex build but that should be done this week, then I can move this stuff out there and actually start building ...and have enough room to have a reasonable chance of success.
    103 and Dillpickle like this.
  2. Jul 8, 2019 #862
    6,527
    2,446
    I'm happy to see that I'm not the only one that has a pile of swarf on my mini lathe/mill. :cool:
    pictsidhe likes this.
  3. Jul 15, 2019 #863
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,710
    184
    Do you have any pictures of any of the parts produced yet?
  4. Jul 15, 2019 #864
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,747
    3,357
    Las Cruces, NM
    This is most of it. It's all going out to the hangar this week. I don't have enough room in my garage to build it so we made room in the build area of the EAA hangar (the Neirrh has priority in the garage). There's good and bad with a group/chapter build but that's my best option right now.
    EDIT: I'll start a build log when I start gluing things together.
    dino, Matt D Murdoch and Tiger Tim like this.
  5. Jul 29, 2019 #865
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,710
    184
    The Ranger and AP reviewd, both with the same idea, the Ranger as a wooden construction and the AP as a pure aluminium buildup.
  6. Jul 29, 2019 #866
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,747
    3,357
    Las Cruces, NM
    An AP made with a Kirk PeeWee "keel style" construction?
    ...just the keel idea, not the formers
    erkki67 likes this.
  7. Aug 4, 2019 #867
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,710
    184
    Is the Ranger thinkable with an overheadstructure like the RW1 or RW6 of Ragwing Aircraft?
  8. Aug 4, 2019 #868
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,747
    3,357
    Las Cruces, NM
    Sure. Just end the pylon at the top longerons and add some cabanes (and the cables etc. to make it rigid). The cabanes would have to be pretty long and might look a little goofy.
  9. Aug 4, 2019 #869
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,710
    184
    So you think it might look odd?
  10. Aug 5, 2019 #870
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,710
    184
    How would it look like with keel?
  11. Aug 6, 2019 #871
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,710
    184
    But this was a great idea, it’s just crazy what a 40HP can cost.
    ScaleBirdsScott likes this.
  12. Aug 6, 2019 #872
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,710
    184
  13. Aug 6, 2019 #873
    litespeed
    litespeed
    litespeed
    May 21, 2008
    1,519
    307
    Sydney
    Did You mean the two stroke or the V twin?
    Any idea on cost and actual weight minus the box?
  14. Aug 6, 2019 #874
    4,240
    1,973
    Would you be trying to run it direct drive, or with a PSRU? Kevin used an Ace redrive to run his previous B&S 627cc hopped-up engine at high RPMs.
    Either direct-drive or with a PSRU, a 670cc air-cooled normally aspirated 4-stroke engine can be expected to give about 23 continuous HP in aircraft use. If we need more than that, then more displacement is needed, pure and simple.
  15. Aug 6, 2019 #875
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,710
    184
    For the 650cc GK is claiming 53hp.which should be plenty of ponies.
    The weight given is for the gearbox, CVT and engine is 72kg ( 159lbs)
    Pricing is to be checked directly with GK.
  16. Aug 6, 2019 #876
    4,240
    1,973
    Yes, but how much power do you need for cruise flight? That engine won't make nearly 53hp continuously, at least not if we want it to to be a reliable engine for flight.
  17. Aug 6, 2019 #877
    apmartin00
    apmartin00
    apmartin00
    Dec 29, 2009
    5
    4
    Moonyoonooka Western Australia
    The Zombug is powered by a vw derived radial 1600cc by Bespoke Engineering. No real info on it, Might just give them a call and ask how light they think they can get the engine for an "offroad" project.
  18. Aug 6, 2019 #878
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,747
    3,357
    Las Cruces, NM
    That sounds awfully optimistic, even for short periods.
    160lbs is too much for the Ranger.
    The Hummel 1/2 VW (that I'm pretty much committed to) makes ~37hp at less than 100 lbs (45kg).
  19. Aug 6, 2019 #879
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,710
    184
    The engine weight is a composition of 3 different El elements.
    The engine
    The continuous variable transmission
    The gearbox.
    The engine itself is most probably in the lower 100lbs range.
  20. Aug 6, 2019 #880
    4,240
    1,973
    Microsport says their SE33 carbureted, direct-drive adaptation of the B&S 810cc engine weighs 77 lbs (32 kg) and produces 33 HP. I'd be highly skeptical that the 33 HP can be produced continuously, but 27 HP continuous would be consistent with other engines of this type and size. These are flying today, so the path has been found (suitable carburetor, prop adapter, ignition, modifications for horizontal mounting and lubrication, etc). New B&S 810cc engines are less that $1000 in the US, and I believe they have dealer support in most other regions of the world.
    For continuous HP, all these air-cooled engines NA 4-strokes will will ultimately be limited by CHTs/cooling. If will an 810cc industrial engine (designed to run all day at 27 HP) can't produce the continuous power you need, it is unlikely that an air-cooled, 4-stroke 650cc engine designed for carts/UTVs will be able to do it.
    Lycoming, Continental, VW, Jabiru, etc: If it is a 4-stroke NA engine in an airplane and the head is directly air cooled, it takes 30-33cc per continuous HP. No induction magic, higher RPMs, rods, high CRs, groovy aftermarket rods or cams, etc have allowed airplanes to exceed that long-term.
