The Ranger, an easily built high wing LSA runabout
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by Victor Bravo, Feb 19, 2019.
  1. Jun 9, 2019 #801
    5,996
    4,801
    I just found out that I am probably going to be the recipient of a pair of Kitfox wings and tails.... at my favorite preferred price point... in the near future. So I might be looking at a custom tinfoil oddball Franken-Hacker version of the Ranger fuselage to make some relatively quick use of these wings.
    pictsidhe and FritzW like this.
  2. Jun 9, 2019 #802
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,524
    164
    Sounds fair.
  3. Jun 9, 2019 #803
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,541
    3,156
    Las Cruces, NM
    How far apart are the spar tubes on the Kitfox wing? I have a mental picture of a slick way to handle the front spar carry through on a tube spar, tin Franken-Ranger.
  4. Jun 9, 2019 #804
    5,996
    4,801
    Not sure yet, don't have them here. But I can do some research online later tonight and see if that number is published. The issue will be using the original Kitfox wing fold on a narrow fuselage. The trailing edges will whack each other. But I do NOT want my version to interfere with the main version development by side-tracking it off on a tangent. That would be a dis-service to the rest of the community. And I'd be pissing off Erkki something awful.
  5. Jun 9, 2019 #805
    plncraze
    plncraze
    plncraze
    May 12, 2006
    1,562
    321
  6. Jun 9, 2019 #806
    5,996
    4,801
    I just saw a number posted that the spar tubes are 27.5" apart. No idea if that is center to center or between faces.
  7. Jun 9, 2019 #807
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,524
    164
    Hey VB, I’m quiet open minded for new solutions! The Ranger has been a constant evolution
    My credo is, the simpler the better, and If I’ve to order 4 spars from the us, the I order 4 spars from the us.
    But I’d like to have the Fritz ribs, no concessions here ;)
  8. Jun 9, 2019 #808
    5,996
    4,801
    Erkki, stick with the original Ranger using the TEAM style wing. I am fortunate to be getting free repairable wings, so that justifies the change. But I have a highly experienced engineer available to watch over me, most people don't have that. The undercambered Kitfox wings will have much more pitching moment, so that will require a different tail as well.
  9. Jun 9, 2019 #809
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,524
    164
    Ok staying with the original solution, that is fine for me as well. :D
  10. Jun 9, 2019 #810
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,541
    3,156
    Las Cruces, NM
    ...I was just thinking out load.
    Nothing is changing on the Ranger.
  11. Jun 9, 2019 #811
    Winchester
    Winchester
    Winchester
    Jul 20, 2010
    65
    15
    Kitsap County Wa.
    40 Pages in for this Post: Can we get a basic summery of what has been completed in the design for The Ranger so far? It seems some people are constructing parts already? I believe the wings are already set in stone, modified Minimax? The Fuselage/Empennage finalized as well? Fritz, will you begin a builders log once you begin gluing your 'kit together? Any way someone like myself can contribute?
  12. Jun 9, 2019 #812
    Will Aldridge
    Will Aldridge
    Will Aldridge
    Oct 30, 2009
    866
    362
    Northern Utah
    What model kitfox? Being that it's undercambered that could mean models 1-3. I have a -1 and plans for the dash 2. The -1 has the narrowest fuselage of them all and they got wider as the series progressed .
  13. Jun 10, 2019 #813
    5,996
    4,801
    Probably a model 2, but unless there's some way of telling I may never know.
  14. Jun 10, 2019 #814
    Will Aldridge
    Will Aldridge
    Will Aldridge
    Oct 30, 2009
    866
    362
    Northern Utah
    I guess in all reality it doesn't matter, just rotate the flaperons perpendicular to the wing and measure from the pivot point on the aft spar to the lower face of the flaperon and multiply by 2 and that's the length of your center section spar, maybe add an inch or 2 just for a little fudge factor.
  15. Jun 10, 2019 #815
    5,996
    4,801
    Yes, and that's what led me to understand that I will have a problem with a narrow Ranger style fuselage. There's 8 inches or a foot between the rear spar and the flaperon pivot.
  16. Jun 10, 2019 #816
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,524
    164
    FA4EE103-8638-4B10-9C72-01119061AD0E.jpeg 33898A46-00C7-4A1C-875A-703083ACB13C.jpeg Easy to overcome, build 1 wing 1-2 inches higher up, so when folding thevwings just overlap.
  17. Jun 10, 2019 #817
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,524
    164
    Off course the lines of the Ranger becomes disturbed a bit:D, but it’s a solution. Another one would be to build only the overhead structure wide enough to use your wings, but the you would require a different kind of wingstrutts arrangement due to the pivoting point.
  18. Jun 10, 2019 #818
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,524
    164
    What about this wing folding geometry on the Ranger?
  19. Jun 14, 2019 #819
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,524
    164
    Is such a wingfolding feature feasible without a too big weight penalty
  20. Jun 14, 2019 #820
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,524
    164
    Fritz, show us the parts coming out of your mill, and even better when the parts comme together!!!!
