The propellers plane of damage ?
Marc Zeitlin
Exalted Grand Poobah
Dec 11, 2015
1,006
Tehachapi, CA
Aesquire
Jul 28, 2014
2,969
Rochester, NY, USA
An early Ultralight pioneer, Paul Yarnell, was doing a foot launch with an Easy Riser when his heel clipped the prop. The tip landed about 300 yards away, and he stopped the engine ( teeth clench kill switch ) before any real damage was done to the airframe. This was a McCulloch MAC-101 direct drive spinning over 10,000 rpm, and a fiberglass prop. Took quite a search to find the tip, about 3 inches long, despite witnesses seeing it fall, seemingly from space.
Cut the heel off his boot and left a nasty bruise, but no other damage, iirc.
wktaylor
Sep 5, 2003
366
Midwest USA
Prop material is 'key' to understanding blade failure mode.
Aluminum blades will fail differently than steel blades and wood-blades and/or 100% composite blades and/or wood-composite blades.
Likewise fixed-pitch prop blade failures are 'simpler' than props with individual blades connected to a 'hub'... more ways to fail.
Vigilant1 [repeat?]. I was the O-2A/B [C337 FAC] lead engineer at SA-ALC in the early 1980s. I investigated a Class A mishap where the rear prop blade separated due to a defective [fatigue-cracked] hub. The first liberated blade severed a boom and the aircraft tumbled into the ground. The hub with the opposite blade simply tore-off the crankshaft flange and went sailing away. That mishap was sad... 2-crew killed due to a 'pencil-whipped' hub inspection. Grounding the O-2 fleet for 'urgent inspections' identified several other Acft with rear-engine cracked blade-hubs. Complacency kills!!! Eventually all rear engine prop-hubs were replaced with up-graded hubs and 'red-colored' hydraulic oil... 'last-chance' to see deep-red-stains leaking-thru cracks during pre/post flight inspections.
