The new project aircraft VP 12. Ukraine
Heliano
Dec 24, 2015
179
Campinas, SP, Brazil
Fantastic! Let us know the specific range figures (Km/l or MPG) in cruise as soon as you get them!
The winglets seem to be at 45 degrees with the wing. I presume they have a toe-in angle. Am I correct?
Alex Aero UA
May 6, 2020
140
Ukraine, Kiev
Thanks for the compliment. Winglets do not have a toe-in angle. Winglets have a special profile.
Alex Aero UA
May 6, 2020
140
Ukraine, Kiev
Testing the VP12 aircraft for stability. Before checking the aileron channel, the trimer was bent upward. The pitch channel was adjusted with an electromechanical trimer. The trimer in the exchange rate channel was not regulated. The aircraft flies steadily without interfering with the longitudinal-lateral control (the pilots do not hold the control stick in their hands, see video from on-board video recorders).
Alex Aero UA
May 6, 2020
140
Ukraine, Kiev
Softex Aero has started a set of static strength tests for the VP12 aircraft.
Wing flap.
VP12 static flap strength tests (simulation of the load on the wing flap at a flight speed of 250 km / h, flap extended 16 degrees, load 384 kg.)
The wing flap of the test was successful, it did not even crackle. After removing the load, no residual deformations or damage were found.
Heliano
Dec 24, 2015
179
1 - When do you intend to do the stall tests? T-tail aircraft, as you certainly know, can have unusual stall characteristics.
2 - Have you ever considered a "RG" (retractable gear) version?
Alex Aero UA
May 6, 2020
140
Ukraine, Kiev
1- Flight tests have just begun.
2- There will be a customer for an aircraft with retractable landing gear, then we will do it. :)
Alex Aero UA
May 6, 2020
140
Ukraine, Kiev
SOFTEX aero 03/12/2021 successfully completed flight tests of the new VP12 aircraft. Many thanks to all the test pilots who made our way to the skies for our aircraft.
On December 24, 2021, SOFTEX Aero received official flight clearance for the new VP-12 aircraft
