The Lone Ranger - a Ranger/SD-1/Aeromax based design
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by rtfm, Aug 6, 2019.
  1. Aug 17, 2019 #21
    rtfm
    rtfm
    rtfm
    Jan 3, 2008
    3,173
    565
    Brisbane, Australia
    Some specs for the Hirth F23. But ye gads - check those prices. Here in OZ we need to add 25%
  2. Aug 17, 2019 #22
    litespeed
    litespeed
    litespeed
    May 21, 2008
    1,390
    246
    Sydney
    Ouch!
    I would shop around- world wide if needed to find a fair price.
  3. Sep 3, 2019 #23
    rtfm
    rtfm
    rtfm
    Jan 3, 2008
    3,173
    565
    Brisbane, Australia
    Hi,
    Been finalising my CAD files and working out (1) what wood I need and (2) how to actually construct what I've drawn. Here are the sheets I'll need for the fuselage. The blue sheets are 3mm, the yellow, 1.5mm
  4. Sep 3, 2019 #24
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,415
    3,035
    Las Cruces, NM
    Just an observation... thin strips of thin ply aren't very stiff when you bend them parallel to the surface grain. It looks like your using a whole lotta ply to add very little strength or stiffness.
  5. Sep 4, 2019 #25
    rtfm
    rtfm
    rtfm
    Jan 3, 2008
    3,173
    565
    Brisbane, Australia
    Hi,
    Ha ha. The ply "strips" are exactly as wide as the 19mm x 19mm Hoop Pine (our version of Spruce) and their job is to position the backing Hoop Pine. Makes actual construction a breeze, because there is absolutely no measuring. And the fillets at the joins act to encapsulate the cnc cut corner reinforcing pieces. Everything bonded with t88
    Duncan
  6. Sep 4, 2019 #26
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,415
    3,035
    Las Cruces, NM
    I know your going to glue the ply to square sticks. I'm just saying those thin strips won't add much strength of stiffness. ...maybe I'm just not seeing how it all goes together yet.
  7. Sep 4, 2019 #27
    12notes
    12notes
    12notes
    Aug 27, 2014
    791
    487
    Louisville, KY
    I think what he was saying is that they are there simply as alignment guides for the square sticks, and not intended to increase stiffness.
  8. Sep 4, 2019 #28
    STDJantar2
    STDJantar2
    STDJantar2
    Jan 31, 2008
    21
    8
    To me seems a lot of wasted wood when cutting out those voids. Why not just use the fillets?
  9. Sep 5, 2019 #29
    radfordc
    radfordc
    radfordc
    Feb 5, 2008
    1,185
    452
    Because for the price of a little plywood you get a perfectly aligned fuselage.
  10. Sep 5, 2019 #30
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,415
    3,035
    Las Cruces, NM
    Like the clecos on the Ranger, perfect/simple alignment is a good thing. But why carry your alignment fixture with you the rest of your life? ...and smearing that much glue during it's very limited open time is going to be a challenge.
    But I don't know what rtfm has in mind, he's probably worked all of that out.
  11. Sep 5, 2019 #31
    rtfm
    rtfm
    rtfm
    Jan 3, 2008
    3,173
    565
    Brisbane, Australia
    Hi. I've worked with t88 quite a lot. Plenty of time. Of course, one wouldn't bond the entire side at once. Outsiders first, then the inside pieces in two passes.
    I worked out the weight of the templates. I can't remember exactly what they weighed, but it wasn't very much.
    As for all the unused bits... I plan to use those areas to cut out a few other parts also, like parts of the tail feathers and the aft fuse. Also to cut some unrelated projects, like a cover for my 3d printer, and some stuff for my wife. Not a lot of wood going to waste.
    Duncan
    akwrencher likes this.
  12. Sep 14, 2019 at 10:28 AM #32
    rtfm
    rtfm
    rtfm
    Jan 3, 2008
    3,173
    565
    Brisbane, Australia
    Hi again,
    I'm back from my business travels. Only to discover that one of the 3D Printed parts for my Lowrider2 CNC router doesn't fit. Bugger. And to compound things, I have bought a new Duet3d WiFi board for the 3D printer, and can't get it to work. Long story short: 3D printer buggered, CNC router waiting for parts. AAAAARGH! Can't stand it.
    Duncan
