Comment probably not needed and possibly not appreciated
. But this is not the result of a bad t-square or drafting machine!
Well working from what we have, yes imported over a large block (easiest way I've found in fusion) ballpark then fine tune, but - haven't run into scaling differences between X and Y so far.
Working with what I've got, take a look at the pic I I threw out to show the inner ply layer around the fuse formers/bulkheads. If you've got 2 groups of squares side by side at different angles, and the lines aren't square or parallel... (Yes I realize thats the rear spar attach, and there's 2deg of dihedral in there on the right one)
Quality seems to vary page to page, so that's why I'm betting - one or more of those T squares have a wobble or just user who didn't give a crap. The airfoil plots are pretty impressive - I remember trying one in HS drafting and getting frustrated as hell.
If you use the standard cookbook formula for tail volume, you will find that the J-1B is lower than the typical acceptable value. Hence the need to lengthen the tail by 10 or 12 inches.
I was thinking of working through the data and trying to get it all into the Roncz spreadsheets later and see how the sizing ballparks look in there.
KR2 before the big stretching trend started, they often increased the Hstab span to get a bit more authority. But I think as drawn might be the starting point.
I seem to recall there was an issue with the J1B main wing angle of incidence as well. Whether the plans have errors or are just not clear on the subject I can't remember but it was discussed on the Yahoo groups years back. Do you have any info?
Haven't looked into the J1B as much (Yeah I prefer my wings below) on the J2 it's definitely a 23015 at +5deg Wing attach are all leaned to match. So at least on the plans I'm working with that's clear
I would love to see a modern iteration of the -1B, -2, or -3 in fiberglass, using the "fold-a-plane" concept, and up-sized for large pilots and the HKS or O-100 engine.
I think you and me are on the same page
Other than the engine. There's a possible wing fold option kitfox style.
