The humble Port-A-Band
Discussion in 'Workshop Tips and Secrets / Tools' started by Little Scrapper, Dec 9, 2016.
  1. Dec 9, 2016 #1
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,397
    3,318
    Wisconsin
    A couple of us on here love our milwaukee Portabands. I
    I know Kevin and I do.
    I've used these since my early apprentice days and have loved them ever since. The portability offers numerous advantages without sacrificing quality of work capacity.
    I figured I'd post this for those looking for a bandsaw but lack room. Portabands are durable and blades are cheap. They run at a low RPM and cut serious metal......accurately once you get used to it.
    I'm building a table, basically a replica of the one pictured below on my 1940's Sears bandsaw.
    The table is for my profile belt sander. I like the simplicity and rawness of my old bandsaw table, so that's my project.
    Below shows how nice it is to use a portaband. Look carefully, the portaband is cutting a miter at 45° 1/8" think steel. With a steady hand it cuts it flat and straight.
    Because it's portable you can cut on clamped parts anywhere.
    If you look closely above the saw is cutting a nice miter on that 1/8" steel.
    And it's accurate in my welding jig. You can see the cut-offs, all this from a stout portable saw.
    Here in the jig mitered, clamped and ready for welding.
    When it comes to homebuilding airplanes and equipping a shop with tools, I wouldn't even do it unless I have one. My standard bandsaw really doesn't get used much.
    Scrap
  2. Dec 9, 2016 #2
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,397
    3,318
    Wisconsin
    Sorry about the rotated photo.
  3. Dec 9, 2016 #3
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,397
    3,318
    Wisconsin
    Better shot of the miter cut. Although it's portable the machine is so incredibly stout that as long as you hold it right and let the saw cut on its own terms..... she'll be accurate for you. In the right hands you can literally shave a 1/16" off.
  4. Dec 9, 2016 #4
    don january
    don january
    don january
    Feb 11, 2015
    2,723
    1,166
    Midwest
    Sweet saw, I bet it would be great to cut up my wifes frozen roast beef also.;) I wonder how it would do on spar tappers? probably great with a fence for guide.
  5. Dec 10, 2016 #5
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,397
    3,318
    Wisconsin
    I don't think I'd get it near a spar. Lol
  6. Dec 10, 2016 #6
    billyvray
    billyvray
    billyvray
    Aug 17, 2005
    728
    236
    Newnan, GA
    Agreed
    I love mine. I've even converted the guide bar to a plate for "non-portable" use.
    Amazing the things I use this for.
    Bill
  7. Dec 10, 2016 #7
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,397
    3,318
    Wisconsin
    Very nice, Bill. Any close ups of that would be great. Did you just bolt a plate on the shoe?
    Throw it in a vice and good to go. Very nice indeed.
  8. Dec 10, 2016 #8
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,397
    3,318
    Wisconsin
    Got her tacked up and mocked up. Thinking about mounting a grinder on the side.
  9. Dec 11, 2016 #9
    12,660
    2,587
    Does that bandsaw work on thin steel tube? Or does it break the blade?
  10. Dec 11, 2016 #10
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,397
    3,318
    Wisconsin
    Works excellent on thin tube because it cuts slow and you can use fine tooth blades.
  11. Dec 11, 2016 #11
    Mark Z
    Mark Z
    Mark Z
    Aug 29, 2012
    560
    284
    Granbury, Texas USA 0TX0
    I've been jonesin' for one of those for too long.
  12. Dec 11, 2016 #12
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,397
    3,318
    Wisconsin
    The Milwaukee brand lasts forever,
  13. Dec 11, 2016 #13
    billyvray
    billyvray
    billyvray
    Aug 17, 2005
    728
    236
    Newnan, GA
    Replace the normal guide with this plate with countersunk holes and a blade slot cut by the saw.
    Little Scrapper likes this.
  14. Dec 11, 2016 #14
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,397
    3,318
    Wisconsin
    I have a stand I got a number of years ago but it was horrible so never used it again. Clamping it up in a vise old school works pretty well.
  15. Dec 15, 2016 #15
    BobbyZ
    BobbyZ
    BobbyZ
    Jan 14, 2010
    228
    66
    Cape May NJ USA and Varna Bulgaria
    They are pretty stout saws.I have a friend who does a lot of towers,railings and arch work on boats and he swears by his.They have to cut all sorts of stuff on site,mainly aluminium tubing but it sure sees plenty of stainless too.They have an old one that they use in a fixture that he made to plug into his hitch and he can feed tubing etc right from the truck bed the fence he made and also a newer portable.The fixture is just fancy clamp that allows him to set angles and it has a fence similar to the one posted here.
    I dont know if I'd use his setup to make cuts with aircraft precision from his truck but he manages to make parts fit good enough for million dollar boats from it.But I'd say if someone wanted they could easily make a similar setup for cutting stuff at home and easily get things as precise as needed.
    They really are a great tool and once you have one most times you wonder how you managed without one.
  16. Dec 15, 2016 #16
    Joe Fisher
    Joe Fisher
    Joe Fisher
    Feb 11, 2007
    1,379
    376
    Glad you guys brought this up I have been thinking of a metal cutting band saw and hadn't thought of one of these. Went to Orschlands and was impressed I will save up for one.
  17. Dec 15, 2016 #17
    Kevin N
    Kevin N
    Kevin N
    Jan 23, 2015
    819
    466
    Your Moms basement
    For you builders reading this it pays to buy quality when buying a port-a-band. Some of the offshore brands are just not worth the headache. If the price of a good one gives you sticker shock think of the term, "buy once, cry once".
  18. Dec 16, 2016 #18
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,397
    3,318
    Wisconsin
    I'm a big fan of the "cry once" mantra like Kevin said.
    Just to reinforce what Kevin said about quality, I can tell you this......
    Before I opened my own plumbing business I was a Forman who had between 20 & 40 guy crews running high rises and hospitals. As you can imagine we had a lot of tools to make this happen. Of all the different tools that make up a job site the Milwaukee brand Port-a-band was pretty much the toughest tool on the site. Each plumber had one and each plumber abused the hell out of them daily. They are about as bullet proof as it gets.
    Things may have changed but I remember 2 different sizes. Get the bigger one. Blades are cheap.
  19. Dec 16, 2016 #19
    Joe Fisher
    Joe Fisher
    Joe Fisher
    Feb 11, 2007
    1,379
    376
    At the Orschlands They had Milwaukee and DeWalt. The Milwaukee has a trigger and a button that both have to be pushed to turn it on. The DeWalt just has a trigger. I really hate these stupid tools that need both my finger and thumb to operate. Also I expect to put it in a vice and mostly use it stationary, so I would just rap a rubber band around the trigger most of the time.
  20. Dec 16, 2016 #20
    billyvray
    billyvray
    billyvray
    Aug 17, 2005
    728
    236
    Newnan, GA
    When using mine as a stationary saw, I clamp the handle in a vise on the bench, and use a spring clamp to hold the trigger. I've seen guys wire in a foot pedal but that seems overkill to me. The clamp works great.
