Sorry, fam. Late forum participant. I have been doing some extensive research into winglets on my tailless E-AB project of late. Although the dynamic scale model flies good on its own without vertical surfaces (which it was originally designed to do), the directional stability data we have been pulling lately still leaves a little wanting. So, after testing over close to 100 iterations of differing configurations, we found out a few basic things:
1. Yes, the winglets to in fact contribute to enhanced directional stability on this aircraft. Significantly enough to strongly consider adding them to the full scale model (which would also require some significant aerodynamic redesign as a result).
2. If configured correctly, the winglets do in fact decrease drag noticeably.
3. As previously discussed, the winglets increase both effective AR and dihedral.
We got as far as getting to what looks like an optimal configuration for this particular aircraft- a split scimitar winglet...similar to what is seen on a 737. However, different airfoils/twists/sweeps/spans, etc would be different between the upper and lower surfaces.
In an effort to validate what we are seeming on simulation, we modified the model, adding a split scimitar winglet system, sized and located with respect to Re, velocities, flight envelope, etc. Here is the result, that will be tested this weekend:
The last picture was taken earlier this week at an open hangar event our local EAA chapter did. Here's to hoping the aircraft behaves on prediction. I'll let you all know the results!
