The Air brake Airbrake dive brake divebrake thread
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by Hot Wings, May 28, 2012.
  1. Sep 19, 2019 #61
    Himat
    Himat
    Himat
    May 5, 2011
    2,797
    645
    Norway
    I would say the added area is not wort the effort.
    I will question if the added area add drag or reduce drag. Same for sealing the box if you think about sealing the box so there will be no flow from one side to the other side of the wing. My guess is that these flows disturb the air and make as much or more drag than a larger area better sealed air brake. Note that the “projected” area into the air stream is the same even with a larger closed area.
