Some more on high-power VW Type 1 engines--grist for the mill:
- Wayne Clagg installed a 2276cc engine in his CH 701, complete with a Valley Engineering 1.6:1 redrive and a 74" Powerfin prop. The redrive allowed him to get an estimated 100HP output from the engine (by running at higher RPMs). He had the (anticipated) problems with shedding heat from the engine. He brazed on the "big fin" mods to the head (which he claimed helped quite a bit), but the engine never proved to be reliable. The total firewall forward weight of the engine with "everything" wound up being 223 lbs, which is a lot. He suffered numerous leaky exhaust valves and a cracked head, so he has now installed a Rotaz 912ULS and is happy with the performance. I don't know if he incorporated Bob Hoover's HVX modifications. Overall, it sounds like the redrive allowed him to produce the HP he wanted, but he was unable to beat the problem of removing heat to keep his temperatures sufficiently low to allow reliable performance over time. The CH 701 is a high drag machine and it's possible a cleaner, faster plane would have been easier to cool, but this certainly supports the idea that these higher HPs are hard to obtain in real aircraft use.
April 2011 Kitplanes article
Video [video]http://www.zenith.aero/video/vw-powered-zenith-ch701sp[/video] of the plane taking off, with some comments.
- Another idea for cooling the VW's heads in higher HP applications (turbo, higher RPM normally aspirated, etc): oil spray bars. Circulating a lot more oil through the VW heads provides a means of removing heat (this is done on the BMW R1200 motorcycle engine and many auto engines, including the Porsche 911 engines). Hoover's HVX modifications improve flow of oil to the head (he mentioned 8x more oil flow than the stock arrangement), and the addition of spray bars with their own direct oil supply would permit even more flow. Here's a picture of one installation (from this site):
Doing this also allows use of cooler oil directly from the oil cooler, the other oil in the head has already picked up heat during a trip through the tappets, pushrods, and rocker shaft. So, you'd have the advantages of more oil, cooler oil, and oil put just where it is needed for cooling.
I've not seen this modification in a flying VW, but I'm far from an expert on this. Again, probably not needed (and just extra complexity) on engines producing up to 80 HP, but might be a good modification if trying to push this engine beyond that. The air/oil cooled BMW motorcyle engines are reportedly getting 100HP reliably from an engine roughly 1/2 the displacement of the large VWs. Yes, that's a different engine designed from scratch to do this (albeit with less cylinder and head internal surface area than the VW has), but it does at least indicate it may be possible to get rid of enough heat with a combination of direct air and oil-to-air cooling, if enough oil is circulated through the heads (to cool them and especially the exhaust valves).
Mark
Mark
