Testing Aircraft Antennas-Standing Wave Ratio
Flyhighdave
Aug 19, 2016
33
USA
I have installed several copper foil antennas in my project (nav, comm, glide slope) and would like to test their function with a swr meter (standing wave ratio). If I understand correctly, the swr meter is hooked up in series in between the transmitter/receiver and the antenna. I am wondering if a handheld type nav/com would serve the purpose for this test. Any advise is much appreciated. Thanks! David
rick9mjn
Mar 14, 2016
23
ni ,ill ,usa
yes a handheld will work.......a good way to learn more about this question ,is to do a google search on Wikipedia for "SWR meter". ............................................................................. good day rick/ ................... IMHO-IMBW,i my humble opinion,i may be wrong
Aerowerx
Dec 1, 2011
5,531
Marion, Ohio
Yes, it will work. But be sure to use an SWR meter made for VHF use. One made for CB (Citizens Band) will give inaccurate readings.
Flyhighdave
Aug 19, 2016
33
USA
Thanks for the advise, Homebuilders. This group is great! I'll move forward with my antenna testing. David
Derswede
Jan 6, 2016
920
Central North Carolina
Check and see if there is a local amateur radio club. A standard VHF SWR bridge is what you will need, and I'd bet you could borrow one easily enough. Aerowerx is correct, the cheap CB meters are normally good to max 50 MHz, in my experience. If anyone in the Winston/ Greensboro NC would like to do this, I do have such a meter and will make it available if needed. Just PM me and we can meet somewhere.
Derswede
BoKu
Pundit
Aug 15, 2013
2,596
Western US
I keep seeing folks say that, but my personal experience indicates otherwise. I use one of those Radio Shack cheapies to tune my antennas, and its numbers seem to correlate well with overall antenna performance. It might not show a numerically accurate SWR, but it certainly seems to show accurate relative values for comparison between antennas (is my homemade antenna as good as this factory antenna) or between configurations (is this length better than that length).
--Bob K.
PW_Plack
May 25, 2015
154
West Valley City, UT
I use one of those Radio Shack cheapies to tune my antennas, and its numbers seem to correlate well with overall antenna performance...
--Bob K.
Then you won a crap shoot. It happens. But the danger remains that if your SWR is too high, the final output stage of your transmitter can be damaged.
A handheld radio can be used, but it may not have adequate carrier power (typically 1 - 1.5 watts for a handheld) to drive the meter to full scale in the calibrate position. Five watts is a safer bet.
The best answer is an antenna analyzer covering VHF. It's much faster, doesn't use your aircraft radio, and puts only a tiny signal through the antenna to reduce the risk of interference. Your local ham radio club will either have one, or have a member who has one. Mine is an MFJ 269, and I'll be happy to help test NAV or COM antennas on experimentals in the Salt Lake area.
