spduffee
I have almost every part of a Teledyne Continental C-145 for sale. I do not have the carburetor, crankcase, camshaft, crankshaft or lifters.
Please feel free to make a reasonable offer on any part. I will remove the parts once sold or state SOLD next to them. Thank you!Teledyne Continental C-145 Parts for Sale
Part Nr. | Description: | My Offer: | |
AN852-10 | 1x Elbow 90deg | $10.00 | |
530163 | 6x Pushrod Housing Flange | $36.00 | |
539840 | 6x Pushrod rubber connector | $5.00 | |
536388-1.25 | 24x Clamps | $5.00 | |
35562 | Thrust washer front/rear | $10.00 | |
639640 | Bearing upper/lower | $10.00 | |
36171 | Bearing Interm and rear main | $10.00 | |
36170 | Bearing Front main | $10.00 | |
530516 | Bearing Front main | $10.00 | |
A35160A2 | 6x Connecting rod assemblies | $120.00 | |
35016 | Crankshaft gear cluster | $150.00 | |
530535 | Camshaft gear | $75.00 | |
530348 | 6x Piston 7:1 | $90.00 | |
530830 | 6x Pison pin | $30.00 | |
640296 | 6x chrome piston rings top | $0.00 | |
640296 | 6x chrome piston rings 2nd | $0.00 | |
640297 | 6x chrome piston rings 3rd | $0.00 | |
640298 | 6x chrome oil control ring | $0.00 | |
641916 | 6x Chrome cylinder | $300.00 | |
21153 | 6x Valve rocker shaft | $36.00 | |
24031 | 6x Inner valve spring | $48.00 | |
24029 | 6x Intrm valve spring | $48.00 | |
625958 | 6x Outer valve spring | $48.00 | |
24026 | 6x Intake valve spring retainer | $0.00 | |
24044 | 6x Exh valve spring retainer | $0.00 | |
21361 | 24x Valve spring locks | $5.00 | |
639614 | 6x Valve rocker arms | $90.00 | |
641792 | 6x Intake valves | $60.00 | |
629404 | 6x Exhaust valves | $60.00 | |
40762 | 6xValve rocker covers | $90.00 | |
641799 | Accessory case | $125.00 | |
641531 | Tach drive adapter assembly | $25.00 | |
530003 | Oil screen assembly | $30.00 | |
633272 | Suction screen assembly | $30.00 | |
No number | Oil sump | $200.00 | |
No number | Dip stick | $10.00 | |
40479 | 2x Int Elbow 2 & 5 | $26.00 | |
40480 | 4x Int Elbow 1-3-4-6 | $52.00 | |
6669 | 2x Intake manifold | $60.00 | |
50309 | Delco-Remy Starter | $100.00 | |
534111 | 12 Volt generator | $100.00 | |
40585 | Fuel pump | $300.00 | |
SF6LN-12 | 2x Magneto | $60.00 |
