Teflon coated wire vs Silicon coated wire
Aerowerx
Dec 1, 2011
5,717
Marion, Ohio
Just guessing from general knowledge but...
Silicone insulated wire is usually used as ignition wiring due to its higher heat resistance. It is also more flexible than Teflon.
I also just read that silicone insulation will burn if held in a flame, and continue burning. Teflon will melt and burn if held in a flame, but will stop burning when the flame is removed. That is why it is used for plenum rated cabling in building construction. IIRC, Teflon is more abrasion resistant.
If you are concerned about a possible electrical fire, I would go with the Teflon insulated wire.
Himat
May 5, 2011
2,868
Norway
Other than when you have looked at it a bit more close, selection of wire insulation is no easy task?
Insulation break down voltage/thickness differ too. Teflon and other insulators in the same group are usually thinner for a given break down voltage than silicon.
