• Homebuilt Airplanes is a vibrant community of pilots, plane builders and industry experts. Our thousands of active members use HBA to trade detailed technical information, discuss best practices, share their builds, plan get-togethers and buy/sell planes & parts. In addition to the community you gain access to, you gain access to over 20 years of curated knowledge by some of the brighest in the industry.
    Access to HBA is subscription based. It is free for 7 days so you can get to know our community!
    Click Here to Become a Member and Access HBA
taer pin reamrs
firebird
Apr 15, 2013
1
cody,wy.
where can I procure, buy, borrow, rent, reamers for the taper pins for my Sonerai ii? No one at the local EAA chapter can give me any advice, so am at a loss on how to get the job done. Reaming the wing/carry-through and fitting aileron links are only thing remaining to complete before cover.
Any and all advice, help is greatly appreciated. (not many resource for help on homebuilts out here in WY)
o2koold
Sep 14, 2006
393
Lander, Wy
Hi Firebird,
You could make a trip to Lander and borrow the main spar reamer from me. I am doing what some others have done on the rear spar, and just using a bolt. I do not recall the bolt size.
Scott R
307.349.8861
Tom H
Jan 17, 2006
113
Shelbyville, Ky
Look at MSC Industrial Supply on-line catalog.
On a S-2, you need a #3 B&S Taper for the rear, and a #5 B&S Taper for the front.
Haven't looked at the cost lately, but 6 - 8 years ago they were about $45/ea.
Tom H
Lil Mikie
Jul 9, 2013
53
Arkansas
Would someone please explain how we attach the wings? Do we use bolts or a special pin or what? Thanks Woody
soneraifred
Jan 12, 2006
1,069
Franksville, WI USA
Woody:
All of the Sonerai's are designed to use AN386 taper pins to secure the wings to the two carry-thru's. Two AN386-5-16A taper pins are used to hold each main spar to the main spar carry-thru. One AN386-3-12A taper pin is used to attach each rear spar to the rear spar carry thru. As Tom H stated, you use Brown & Sharpe #5 and #3 taper reamers to finish the holes with each spar mounted in the carry-thru's. When I built my airplane, I drilled and reamed the main spar and carry-thru on my drill press before assembling the wings. The rear spar pin holes were drilled and reamed in place in the fuselage after the wings were completed. It is possible to drill and ream the main spar holes in the fuselage with the wings completed. It's just a little more difficult.
Lil Mikie
Jul 9, 2013
53
Arkansas
Thanks for a quick reply Fred. This plane was flying at one time so I only needed to know what type of bolt to use. Woody
Lil Mikie
Jul 9, 2013
53
Arkansas
Well, I haven't tried to find any yet. I'm sure someone has them. G.P should have them or be able to direct us in the right direction. W
racegunz
Dec 3, 2008
347
Indiana usa
I read somewhere on here that GP's are not "standard" AN386 taper pins. I'll call them and see what's up with the pins they are selling.
smoothmat
Oct 14, 2010
161
I seem to recall finding them at aircraft spruce. I lost a few over the winter so I had to procure some more. I bought them from aircraft spruce. I believe they were a B/O item or something as it took a while to receive them.
Lil Mikie
Jul 9, 2013
53
Arkansas
Thanks Smoothmat ~~ I'll try them even if we have to backorder them. I'm sure there are others that will have to address this also.
Lil Mikie
Jul 9, 2013
53
Arkansas
Aircraft Spruce has the rear pins for the wings. Haven't found the front pins yet.
The rear pins are coming from California. W
dcstrng
Oct 17, 2010
1,193
VA or NoDak
racegunz said:
The largest that Aircraft Spruce has on the web is AN386-4-12 ???
That's all they have in the catalog as well -- I gather GP still has "appropriately” sized pins ??
Is it possible to use an appropriate AN-bolt/nut arrangement? I’ve looked through the galleries and it looks like some may have done so (appeared to be bolt/nut arrangements because there are “wrenching surfaces” on both ends of a couple pics), although they may also just be temporary fasteners for the spar carry-through during fabrication.
dcstrng
Oct 17, 2010
1,193
VA or NoDak
OK -- I just ordered `em from GP (and when they arrive, i shall but them in a safety-deposit box until I need `em ;) )
Lil Mikie
Jul 9, 2013
53
Arkansas
Good for you! I'll order them today as well. I have looked everywhere on the net and did not turn up any. There was one place in Boston that had them but the lady would not even talk to me. I'm going to order two sets just in case. W
Pttim
Mar 2, 2008
1,648
Pennsylvania
I looked for these pins once myself when I had misplaced one of mine..the price was SCARY! I went looking again an finally found them.
